To change or not?
by ram_man
Yesterday at 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
Yesterday at 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
Yesterday at 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
Yesterday at 10:51 PM
whole hog cook w/ pics
by 04SE
Yesterday at 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
Yesterday at 09:37 PM
How to post UOA's on here?
by motor_oil_madman
Yesterday at 09:34 PM
Remanns Brand Remanufactured engines
by TiredTrucker
Yesterday at 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
Yesterday at 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
Yesterday at 08:57 PM
Gas prices do the ol' switcheroo
by grampi
Yesterday at 08:44 PM
Possible Valve adjustment needed?
by andrewp1998
Yesterday at 08:16 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
47 registered (95wagon, 2015_PSD, Anthony, bmod305, 901Memphis, cjcride, 5 invisible), 1161 Guests and 7 Spiders online.
58645 Members
66 Forums
252427 Topics
Page 1 of 2 1 2 >
#2131375 - 01/07/11 09:03 PM AC DELCO PF 48
electrolover Offline
Loc: TEXAS
does anyone have experience with this filter??
is it original equipment?
will it hold up with out failure to normal ocis?
i have searched but all the pics have been deleted of it cut open. i like the price and hope its quality is at least competitive with the MOTORCRAFT.
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
#2131380 - 01/07/11 09:09 PM Re: AC DELCO PF 48 [Re: electrolover]
crazyoildude Online   content
Loc: New Jersey
i have used a/c delco oil filters for as long as i remember on all my gm cars but i STOPPED using them when they went to e core
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#2131438 - 01/07/11 10:17 PM Re: AC DELCO PF 48 [Re: electrolover]
defektes Offline
Loc: Hesperia, CA, USA
Good filter, but I'd save the cash and use a ST for a dollar or two less.
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
#2131491 - 01/07/11 11:02 PM Re: AC DELCO PF 48 [Re: electrolover]
jb10484 Offline
Loc: Bettendorf, Iowa
I have one on my 2010 Saturn Outlook currently. I changed one back in November, but didn't cut it open as it was only my third time changing the oil on my vehicles and caring about the results. My next oil change on it will be late February and I will cut it open then. I have not had any issues with it so far.
2010 Saturn Outlook XR
Pennzoil Platinum 5W-30 Microgard Filter
2005 Dodge Grand Caravan SXT
G-Oil 5W-30 STP Filter
#2131564 - 01/08/11 12:21 AM Re: AC DELCO PF 48 [Re: crazyoildude]
Loc: TEXAS
that was the first thing i looked for. its got steel tube with small holes, alot, but very small. they look punched rather than drilled
#2131665 - 01/08/11 07:15 AM Re: AC DELCO PF 48 [Re: electrolover]
paulswagelock Offline
Loc: Pennsylvania
My Tahoe uses the pf48. I do not believe this model to be an ecore design. I did see the pics of one cut open before they were removed and it's construction appeared fine, acceptable, especially given the $3.49 price.
'15 Subura Impreza Sport
'13 Corolla 1.8L
'15 Ram Laramie Crew cab Hemi
'12 Toyota Rav4
'14 Acura ILX
#2131672 - 01/08/11 07:24 AM Re: AC DELCO PF 48 [Re: electrolover]
Loc: TEXAS
do they have metal end caps?
#2131700 - 01/08/11 08:02 AM Re: AC DELCO PF 48 [Re: electrolover]
cronk Offline
Loc: Watertown, New York
On the Delco filters, if it has a metal center tube, it has metal end caps. Champ classic filter, excellent filter for the money.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
#2131804 - 01/08/11 09:52 AM Re: AC DELCO PF 48 [Re: electrolover]
Loc: TEXAS
thank you for the info. i plan on installing one on my mother-in-law's traverse today. if its a quality filter i will stick with it.
#2132113 - 01/08/11 02:28 PM Re: AC DELCO PF 48 [Re: electrolover]
Loc: TEXAS
well i changed her oil today and removed a pennzoil pz 167 filter. i was curious so i cut it open for inspection. my first thought was its a good filter with metal end caps and an anti drain back valve, but as soon as i touched the element i thought differently. it had 3k on it and was very brittle. no tears until i pushed on it, then it seemed to crack. when i disassembled the element i found that the material was very thin and hard. not even half the thickness of my 820s material that lay next to it.
my thoughts are if you use an oil change shop bring your own quality filter.
#2132206 - 01/08/11 04:29 PM Re: AC DELCO PF 48 [Re: electrolover]
99 GASE2 Offline
Loc: Toronto, ON, Canada
The AC Delco PF-48 is the stock oil filter for LS3 small block V8 engines, like for the Corvette.
& others like my Pontiac G8 GT.
I use the NAPA Gold 7060 oil filter.
You can go to Wix Filters, & see what other OEM application calls for it.
http://www.wixfilters.com/filterlookup/results.asp?PartNo=pf48&Submit=Search
Edited by 99 GASE2 (01/08/11 04:32 PM)
'14 Crystal Red Tintcoat Camaro SS RS Coupe
with L99 6.2L small block V8 & a 6L80 transmission
#2132308 - 01/08/11 06:02 PM Re: AC DELCO PF 48 [Re: electrolover]
AMC Offline
Loc: South Eastern, CT
Check out the write up I did in the link below. I compare a Purolator and Napa Gold to the PF48 in this filter application. The AC delco is a pretty good filter but I think the purolator classic is better for the same price.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2105249&page=1
11 Chevy Silverado - PP 5w-30
10 Ford Focus - WH 5w-20
14 Yamaha Super Tenere - Delo 15w-40
1oz TCW-3 Per 5 Gallons of Fuel.
#2132335 - 01/08/11 06:44 PM Re: AC DELCO PF 48 [Re: electrolover]
Loc: TEXAS
hey thanx for the link!!
so where are you getting purolators for 4 bucks??
#2132740 - 01/09/11 06:38 AM Re: AC DELCO PF 48 [Re: electrolover]
AMC Offline
Advance auto parts or AAP as we often call it on this forum. If you go to their website, you can buy them online and use promo code p20 during checkout and get 20% off your order.
The purolator classic is the filter I would use if I was changing oil for somebody else and didn't want to spend too much. I see you already installed the AC Delco though, no worries that is a good filter too. On page 2 of the link in my first response, I cut the AC delco open and it looked pretty good.
#2132742 - 01/09/11 06:40 AM Re: AC DELCO PF 48 [Re: electrolover]
cronk Offline
I think if you did a cut away, you would find the Delco has more pleats than a Puro Classic. Always used to anyways.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
Page 1 of 2 1 2 >
