It works fine for those of us who don't own air or power tools and don't care to buy them. It's cheap (I paid $8.47 but I've been told they're $6-something at most other WM's) and it includes a lot of goodies:
I started out with this mess:
After using only the lens clarifying compound to no avail, I went to town with the little sanding pads, lubricant, and fresh tap water from the hose. The first two sanding pads are a medium fine grit, I figure 800 and 1000 or something. They got all the yellowing out:
After the next sanding pad which is two sided and fine, maybe 1500 and 2000, I saw a nice difference and could see inside the light a lot better:
Then I whipped out my cheap redneck version of a terry towel (crew sock turned inside out) and went to town with the clarifying compound. Results were awesome:
I then did the other side, waited for it to dry, then used the foodservice glove and the sealing wipe to protect both lenses:
That picture was taken the next day after the sealant had time to cure. It's been almost two weeks, they still look the same. I'll update after a few more weeks and see how well they held up in the faux-winter driving we get here in north Texas.
Driving at night is safe again (if you avoid the drunks). For $9 this is way better than spending $150+ on replacement capsules. I have plenty of lubricant and clarifying compound left over and I can always get more sandpaper if needed. The fact that this has four different grits, compound, sealant, and lube makes it a really good deal. All you have to come up with is a buffing towel (I used the outside of the sock), applicator (which was the inside of the sock), and a clean water supply (so those of you in Pensacola, who have the #1 worst city water supply in the nation, get a bottle).
