Idle Jitters No Codes
by Merkava_4
29 minutes 35 seconds ago
Long commute, OCI and synthetic vs blend?
by rebelx
Today at 02:18 AM
good prepaid cell phone?
by Oldtom
Today at 12:42 AM
Waterproof gun bag?
by 901Memphis
Yesterday at 11:59 PM
Admin trash the 2 oldest VOAs I posted
by Mainia
Yesterday at 11:09 PM
Atlas Copco Roto-Xtend Rotary Screw Comp Oil VOA
by Mainia
Yesterday at 11:06 PM
"Global" antifreeze - contains EHA/2EHA?
by Jonzobot
Yesterday at 11:03 PM
Schaeffer's# 158 Moly Pure Synthetic Comp. Oil VOA
by Mainia
Yesterday at 10:41 PM
by Mainia
Yesterday at 10:36 PM
My CarQuest premium filter??
by MNfarmer33
Yesterday at 10:26 PM
Incandescent Light History and Metallurgy
by MolaKule
Yesterday at 09:54 PM
Pass Word Changed?
by ls973800
Yesterday at 09:26 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
14 registered (Farmer, Ifixyawata, Merkava_4, GREBOW, Robenstein, 1 invisible), 767 Guests and 11 Spiders online.
58322 Members
66 Forums
251015 Topics
#2009433 - 09/06/10 07:38 PM Reusing Head Gaskets
WagonBoss Offline
Loc: Northern Virginia
I'm working through a compression issue on a single cylinder Kawasaki. I pulled the head and it is not warped. Can I reuse the head gasket or is a new one required?
2009 Outback 2.5i
2008 Impreza 2.5i
L14460/Formula Shell 5w-30
2004 Corolla
L14476/Formula Shell 5w-30
2012 Chrysler 300
Wix 57526/QSUD 5w-30
#2009436 - 09/06/10 07:42 PM Re: Reusing Head Gaskets [Re: WagonBoss]
Panzerman Offline
Loc: Port Orange, Florida
I was always under the assumption to use a new head gasket, but the last time I re-used the old head gasket and had no issues. It was copper and a single cylinder air cooled two stroke. With water cooled, I would probably opt to get a new gasket. It all depends on how hard it is to replace later, if there is a issue.
2007 Ford F-150 FX-2 73,000
2007 Ford F-150 FX-4 198,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 69,000
2002 Lincoln Continental 153,000
#2009440 - 09/06/10 07:44 PM Re: Reusing Head Gaskets [Re: Panzerman]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
Id get a new gasket.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#2009496 - 09/06/10 08:27 PM Re: Reusing Head Gaskets [Re: xxch4osxx]
greenaccord02 Offline
Loc: Houston, Tx, USA
Briggs always says you can reuse the gaskets if they don't come apart and I've done that without issue many times, but if there's any question about it or if you just want to follow best practices, get yourself a new one.
  1. '95 Dakota 3.9L - M1 0W-40 - MC FL1A
  2. '97 Accord F22-B1 - M1 5W-30 - Bosch 3312
  3. '99 Camry 1MZ-FE - PP 5W-30 - M1-209
#2009518 - 09/06/10 08:41 PM Re: Reusing Head Gaskets [Re: greenaccord02]
Brett Miller Offline
Loc: Arizona
No worries when recycling the head gasket, I'd run the same head gasket for a couple years when I built and raced 5hp WKA.
#2009530 - 09/06/10 08:49 PM Re: Reusing Head Gaskets [Re: Brett Miller]
Eddie Offline
Loc: Florida, Cape Coral
Just make absolutely sure the head and cyl mating surfaces are flat and an eye ball estimate is not good enough in my opinion. Use a machinist straight edge and 0.0005 feeler gages
CX5 Touring 2.5L :-)
#2009588 - 09/06/10 09:41 PM Re: Reusing Head Gaskets [Re: Eddie]
hardcore302 Offline
Loc: Suffolk County, NY
If the surfaces are even minutely uneven, you could have problems. I would use a new one.
2007 Ford Mustang GT - Motorcraft filter, Castrol GTX SynBlend
2011 Chevy Equinox LT - Driveworks filter, Pennzoil Platinum
#2009636 - 09/06/10 10:39 PM Re: Reusing Head Gaskets [Re: hardcore302]
dwendt44 Offline
Loc: Central Wisconsin
I do recall an old article about using a 'used' head gasket on british cycles that said to 'cook' the head gasket at 250 for 20 minutes, and then spray with a copper base spray made for gaskets.(time and temp are guesses)
It was supposed to work but 'expanding' the gasket. The spray helped seal the surface.
Newer gaskets are made different so I don't know it that would work anymore.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#2009732 - 09/07/10 02:40 AM Re: Reusing Head Gaskets [Re: WagonBoss]
JTK Offline
Loc: Buffalo, NY
Is this an OHV Kawi or an old flat head? With flat heads I would'nt sweat reusing the HG at all. If it's OHV where there's lots more steps to removing/replacing the head, I'd use a new gasket for sure.
Joel
Edited by JTK (09/07/10 02:41 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2009779 - 09/07/10 06:32 AM Re: Reusing Head Gaskets [Re: WagonBoss]
WagonBoss Offline
Thanks. It's a flat head. This project is becoming more involved and costly than I had wanted it to. I'll reuse the old gasket for now, unless I can find one locally today. If I can get any compression at all I'll be ahead of where I was. It's relatively easy to go back later with a new gasket. I just want to see if I'm making progress or not. Probably time for the junk yard.
2009 Outback 2.5i
2008 Impreza 2.5i
2004 Corolla
2012 Chrysler 300
#2009878 - 09/07/10 09:24 AM Re: Reusing Head Gaskets [Re: dwendt44]
boraticus Offline
Loc: Canada
Good advice dw.
The heating process you've mentioned is known as annealing.
Definition: Heating steel to, and holding at a suitable temperature, followed by relatively slow cooling. The purpose of annealing may be to remove stresses, to soften the steel, to improve machinability, to improve cold working properties, to obtain a desired structure. The annealing process usually involves allowing the steel to cool slowly in the furnace.
Many people use this process to "recondition" copper head gaskets on vintage two cycle motorcycles. We generally use a butane/propane torch to heat the gasket then let it cool. If the gasket is not showing any signs of fracture, I'd anneal it and re-use it without hesitation.
#2010212 - 09/07/10 03:06 PM Re: Reusing Head Gaskets [Re: boraticus]
Kestas Offline
Loc: The Motor City
Copper anneals at 750F (400C).
#2010661 - 09/08/10 12:18 AM Re: Reusing Head Gaskets [Re: Kestas]
dwendt44 Offline
I think the idea was that the copper sheet would expand a bit after being compressed for years/miles.
#2010889 - 09/08/10 09:23 AM Re: Reusing Head Gaskets [Re: dwendt44]
Kestas Offline
Loc: The Motor City
Don't expect copper to "relax" the same way elastomers do. It'll only relax (instantaneously) as much as its elastic properties allow. Heat will not expand the metal. Heat just anneals the hardened metal so it can be further compressed without excessive strain hardening.
