Originally Posted By: StevieC
Maybe it is the cooling system lubricant I use in the system that creates the difference between the times of year.
My view is that some vehicles simply have oddball cooling systems. Combined with airflow, radiator efficiency, thermostat range, and the wonky Canadian winters you and I both experience, I have seen a few weird ones, but only a few.
All the F-150s and Town Cars I've driven have been fairly steady, regardless of whether it's the hottest day in July or the worst day in January. An LTD I had was a little different. It had trouble heating up in the winter since I over-beefed-up the cooling system thanks to a couple summer issues. It had the A/C rad with a little engine and a giant flex fan direct mounted. Fine in the summer, not so fine in the winter.
With my Audi, if it's a cooler day, say 15 C or below, the temperature gauge stays a bit lower. I'm speaking of highway driving so we have consistent cooling. It doesn't get any lower than it does at 15 C, no matter how cold it gets outside. If the ambient temperature is warmer than that, the operating temperature rises a few degrees. When the outside temperature hits about 25 C, the operating temperature hits a maximum and won't go up more, even if it's 35 C outside.
Fluctuations in temperature can be observed when idling in traffic and the fan kicks in and out.
