Originally Posted By: AMRoberts
Geo_Prizm,
At the time of the sample, 140,519 miles on the vehicle. Not really a full set of service records from the previous owner. Looks like he was using Mobil 1 early on, but record-keeping stopped at some point. No clear indication what was in the sump when I bought it.
The M104 engine has dual overhead cams where the cam lobe directly contacts the flat surface of the lifter ... No rollers. Seems like an argument for trying to keep the extreme pressure anti-wear additives as close as possible to how oil was formulated in the mid-90s (within reason, I'm not going to run $$/quart racing oil).
The data I've been able to find for the Mobil oils implies higher ZDDP for the High Mileage (900 ppm Phosphorus, 1000 ppm Zinc), even more for the 0W-40 (1000 ppm P, 1100 ppm Zn), and still higher for the 5W-40 Turbo Diesel Truck (1100 ppm P, 1200 ppm Zn).
The 10W-40 HM was the best deal in the local WalMart the day I went to get oil ... It was $23 per five-quart jug, while the only 0W-40 and 5W-40 TDT on the shelf (that day) were single quarts.
My '94 Geo Prizm has DOHC engine too,and it has 140K miles on it.I have the car for a little over 2 years.So I do not know anything about the maintenance history of the car ether. When I first started using synthetic oil I blended 1 quart of M1 HM 10W-30 and 3qts of M1 EP 10W-30 in order to prevent a possible leak.No leaks so I started using GC 0W-30 and now M1 0W-40.
If there is an autoparts store near you, you can get 5 qts (single qts or a 5qt container) of M1 0W-40 (any Mobil 1) and a quality Mobil 1 oil filter for $29.99, sometimes even cheaper than that.
By the way I read the UOA again, it is impressive for 8229 miles with a TBN of 5.
