Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
9 minutes 58 seconds ago
Clean battery with garden hose?
by SavagePatch
Yesterday at 11:55 PM
Toyota 5w20 blend?
by researcher
Yesterday at 11:36 PM
Smoked some baby backs today
by BeerCan
Yesterday at 10:28 PM
Ford FWD axle replacement
by 2009Edge
Yesterday at 10:27 PM
Saturn ac compressor
by spasm3
Yesterday at 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
Yesterday at 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
Yesterday at 10:11 PM
moly + engine coatings
by benjy
Yesterday at 09:57 PM
Worth the upgrade?
by daves87rs
Yesterday at 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
Yesterday at 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
Yesterday at 09:11 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
27 registered (Branson304, c502cid, alcyon, ag_ghost, carlprop, Anduril, 4 invisible), 925 Guests and 12 Spiders online.
58584 Members
66 Forums
252219 Topics
#1804163 - 03/04/10 09:04 PM 07 Mustang Power Steering Fluid
HaroldCallahan Offline
Loc: Northern Colorado
Doing oil change this evening on my '07 Mustang and noticed the power steering fluid is at the add mark. Manual says to use Mercon fluid.
Is Valvoline DexMerc going to be OK to use, or is there something else that I should be putting in there ?
Thanks
#1804164 - 03/04/10 09:05 PM Re: 07 Mustang Power Steering Fluid [Re: HaroldCallahan]
Nick R Offline
Loc: Albany, NY
Mobil 1 ATF would be my choice.
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#1804168 - 03/04/10 09:08 PM Re: 07 Mustang Power Steering Fluid [Re: Nick R]
AdRock Offline
Loc: Texas
Same here. M1 ATF is great stuff. My PS seems to like it much better than the mercon.
Edited by AdRock (03/04/10 09:09 PM)
2002 Mustang GT
1995 Ford F150
2003 Honda Accord
#1804171 - 03/04/10 09:09 PM Re: 07 Mustang Power Steering Fluid [Re: HaroldCallahan]
beast3300 Offline
Loc: Ohio
Thanks
Yes that will be fine.
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#1804212 - 03/04/10 09:49 PM Re: 07 Mustang Power Steering Fluid [Re: beast3300]
ewetho Offline
Loc: Kankakee, IL
We only use Mercon V at the dealer. It is what is in it from the factory.
I would stick to that.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#1804216 - 03/04/10 09:50 PM Re: 07 Mustang Power Steering Fluid [Re: ewetho]
Nick R Offline
Loc: Albany, NY
I actually use a sort of combination. I originally replaced the PSF with Valvoline MAxlife PSF, and it became way too loose and light. Changed some out for 1 qt of Mobil 1 ATF, didn't get much better. Added a bottle of Lucas Power Steering stuff, and it's just right now. Middling in weight, and it's not loose on center anymore.
Edited by rudolphna (03/04/10 09:51 PM)
#1804272 - 03/04/10 10:40 PM Re: 07 Mustang Power Steering Fluid [Re: Nick R]
dsmith41 Offline
Loc: Kansas City Metro
I used Dex/Merc in my Ford truck when I replaced the P/S fluid back in December and it works fine. It called for Mercon as well.
1995 Ford Ranger 2.3L
2001 Chevy Impala 3800
1980 Wheel Horse C-145 8 Speed
#1804375 - 03/05/10 02:09 AM Re: 07 Mustang Power Steering Fluid [Re: dsmith41]
hardcore302 Offline
Loc: Suffolk County, NY
Regular Dex/Merc I use Castrol. Mercon V is for the actual Auto tranny, not for ps
2007 Ford Mustang GT - Motorcraft filter, Castrol GTX SynBlend
2011 Chevy Equinox LT - Driveworks filter, Pennzoil Platinum
#1804425 - 03/05/10 06:25 AM Re: 07 Mustang Power Steering Fluid [Re: hardcore302]
mechtech2 Offline
Loc: Chicago Area
Power steering systems can run very hot in summer.
A full synthetic fluid is a good idea.
A few turkey baster empty/fills in succession is a great idea to get fresh fluid in the system with no mess, and no removal of lines.
Mobil 1 or Mercon V are goo fluid options.
My concern is where that fluid is going in a rather new car - why it is low. This should not be. Hopefully you have an easy leak to fix.
#1804591 - 03/05/10 08:44 AM Re: 07 Mustang Power Steering Fluid [Re: mechtech2]
tig1 Offline
Loc: Illinois
I do the turkey baster drain and fill with M1 ATF in my Fords. Have used their fluid since they invented the stuff in the early 90s with never a failure, tranny or PS pump, yet.
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1804761 - 03/05/10 10:56 AM Re: 07 Mustang Power Steering Fluid [Re: tig1]
bdcardinal Offline
Loc: Santa Barbara, CA
Any Mercon V for the P/S will work. It's what was in there when new.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#1805068 - 03/05/10 03:08 PM Re: 07 Mustang Power Steering Fluid [Re: mechtech2]
The owner manual specifies Mercon 5 for Auto Transmissions and Mercon for the PS and the manual transmission as well.
Hard to find just plain Mercon unless you go straight to Ford, I suppose.
I guess I will just use the DexMerc as it does meet Mercon specs. I too wonder why it is down to the add mark. Never was all the way to full in the beginning. I have not seen a single drop of anything leak from this car. Looked underneath and found nothing on the frame or anywhere else. It has almost 50k miles.
#1805070 - 03/05/10 03:10 PM Re: 07 Mustang Power Steering Fluid [Re: HaroldCallahan]
Nick R Offline
Loc: Albany, NY
Mercon V has been speced for ford vehicles since the late 90s, early 2000s. Mercon is no longer licensed. Dex/Merc will work, but Mercon V is a much better fluid.
