Scratched wheel
by gabriel9766
18 minutes 42 seconds ago
Gear oil added to motor oil in engine
by TiredTrucker
18 minutes 48 seconds ago
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
19 minutes 48 seconds ago
A Tesla Model S on auto-pilot was in a fatal crash
by JimPghPA
22 minutes 8 seconds ago
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (5316Mi)
by DuckRyder
Today at 05:00 PM
By law, do owners have to comply with recall ?
by HTSS_TR
Today at 04:54 PM
Stuck ring?
by TurboFiat124
Today at 04:16 PM
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
Today at 03:17 PM
Jeep brakes
by buck91
Today at 03:10 PM
Any thoughts on the Hersheys attempted buyout?
by Vern_in_IL
Today at 02:55 PM
2009 Miata Race Car, M1 5w20
by 09_GXP
Today at 02:48 PM
FRAM TG3600 Cut Open
by HX520W
Today at 02:30 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
79 registered (AlienBug, 09_GXP, 2004tdigls, 901Memphis, AandPDan, AirgunSavant, 6 invisible), 1830 Guests and 9 Spiders online.
58322 Members
66 Forums
251052 Topics
Page 1 of 10 1 2 3 ... 9 10 >
#177445 - 02/18/06 03:32 PM Using Heavier Weight Oil
Cogito Offline
Loc: Chicago
Are there any problems with using a heavier weight oil like 10W50, 20W50, 5W50, 10W40, etc., instead of 10W30 or 5W30 in a new car (Civic), besides lower MPG? Does it have any good or bad effects on the life of the engine?
#177446 - 02/18/06 04:38 PM Re: Using Heavier Weight Oil
GoldenRod Offline
Loc: Clovis, CA
For lack of a better term; it may not be able to "squeeze" into where it needs to go.
#177447 - 02/18/06 04:54 PM Re: Using Heavier Weight Oil
Al Offline
Loc: Elizabethtown, Pa
There are no upsides. 20 and 30 weights have proven to be adequate. Newer cars are designed with bearing clearances and areas to run with lighter oils. Thicker is not better anymore.
Not sure anyone here can positively say that it can "hurt" though.
#177448 - 02/18/06 05:36 PM Re: Using Heavier Weight Oil
TallPaul Offline
Loc: By Detroit
What is the reason you want to run the thicker oil? Obviously you can't go thicker than 10w30 in winter and it your temperature is frequently below 0 F, a 5w30 would be highly recommended, in fact synthetic would be better.
I just cold started my motorhome after a night it dropped to about 5 F and the motorhome had sat for 2 months. It fired up very nicely on the 10w30 Pennzoil SL Synthetic. Probably was around 8 or 10 F when I started it, not sure exactly. I think the Maxlife 10w30 I had been running would have been much worse for startup.
#177449 - 02/18/06 06:03 PM Re: Using Heavier Weight Oil
Ed_T Offline
Loc: Taxachusettstan
One way to determine that might be to see what the European oil recommendations are for the same engine.
The Euro's seem to rec higher weights generally, but we have CAFE here in the U.S.
I use a 5w-40 synth where the mfr recs a 5w-30. I just think its better protection and performance, although I surmise about a 1mpg hit.
#177450 - 02/18/06 06:42 PM Re: Using Heavier Weight Oil
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
If the engine is an overhead single/dual cam, I would not go more than (1) [email protected] beyond what the new owner's manual recommends. I would be leery to purchase 10W oils also.
For instance... if it calls for 5W-30, the thicklest ones are 12 cSt. So I would not exceed 13 cSt personally - so start-up lubrication in your Chicago winters remains respectable.
Just my amatuer opinion here...
#177451 - 02/18/06 07:39 PM Re: Using Heavier Weight Oil
Cogito Offline
Loc: Chicago
I'm not concerned about cold weather startup. I bought this Civic in 89 and consistently used those heavyweights of GTX for the first 90,000 miles. Then someone told me it was a bad idea, and I switched to xW30. I've got 120,000 on it now, and it seems to use some oil, maybe a quart every 6-800 miles, but doesn't seem to burn it. I don't see any smoke. And there are no leaks. I can't figure out where it goes. I'm just wondering if I jacked something up in the engine from all those years of using the heavier weight oil? What could be happening to the oil?
#177452 - 02/19/06 08:13 AM Re: Using Heavier Weight Oil
reyjay1 Offline
Loc: N. Texas
It may be that engines just get 'used to' a particular weight of oil like when run for that many miles on them, I would think a 5w40 would be ideal for your situation.
a quart in that many miles you will not be able to see it, unless maybe you followed yourseldf and noticed a little bit of smoke every now and then, but it is going out your tailpipe. certainly the rings are a bit stuck and a good clean might eliminate your consumption.
#177453 - 02/19/06 08:48 AM Re: Using Heavier Weight Oil
GoldenRod Offline
Loc: Clovis, CA
It seams to me that the clearances in your motor have increased in order to accommodate the heavier oil.
#177454 - 02/19/06 08:58 AM Re: Using Heavier Weight Oil
Master ACiD Offline
Loc: sebring, florida
it wouldnt hurt anything to run thicker oil. the question is, would it help anything?
i have ran everything from 5w30 to straight 30 and even 20w50 in the honda crv.
it didnt hurt a thing, although i dont believe it has anything positive to benefit.
#177455 - 02/18/06 11:50 PM Re: Using Heavier Weight Oil
TallPaul Offline
Loc: By Detroit
You may be on to something, but I cannot imagine how the clearances could increase in response to thick oil.
#177456 - 02/19/06 12:48 AM Re: Using Heavier Weight Oil
Steve S Offline
Loc: East of IGO
Goldenrod,splain to me how for a better term higher viscosity oil may not be able to "squeeze" into where it needs to go
#177457 - 02/19/06 01:09 AM Re: Using Heavier Weight Oil
mechtech Offline
Loc: Chicago area
Heavier oil doesn't "squeeze" into smaller spaces as fast. It doesn't flow as well as thinner oils.
The cam oil sensor light on my old GTi would take much longer to go out with 20-50 than 10-40.
The oil just couldn't get up there and do any good until more time, and wear, occured.
#177458 - 02/19/06 03:15 AM Re: Using Heavier Weight Oil
Al Offline
"You may be on to something, but I cannot imagine how the clearances could increase in response to thick oil. "
Nor can I but I can't say its unreasonable though.
Maybe the best would go give it a good AutoRx to free up the rings and then go thth the thinest oil (above a 20 wt where oil use is not excessive. Again..40's O.K.(albeit not necessary) but I wouldn't jgo to 50.
#177459 - 02/19/06 04:15 AM Re: Using Heavier Weight Oil
JohnBrowning Offline
Loc: USA
Either pick up two bottles of Auto-RX or a gallon of Lube Control. If you want to use a thicker oil try to use a 5W40,5W50 etc... It does not make sense to give up cold start performance just to get thicker. Now when it is warm out their is nothing wrong with 15W40.
The reason for useing either LC or ARX is to clean the ring pack area.
