Hi guys,
this is going to burn a hole in my head! I've been sitting on the fence about running synthetic in my Jeeps diffs, just to lessen the amount of changes I need to make, and a little more cold weather protection.
I spoke with Currie AND TrueHi9, and they both recommend a 80w140 NON synthetic oil. they were both very decent to take the time to explain to me why they chose a non synthetic oil. Mike from Truehi9 is a excellent guy to chat with if you ever have any questions. But I'm still not convinced its the same for all applications.
Everyone has been jumping on the bandwagon on not using synthetics in the diffs over at Jeepforums.
Where is the truth????? The way I see it, there is a common trend in axle manufacturers that recommend only conventional gear oil. they all make high pinion axles. I could see the synthetic not being drawn up as well or "flung" into the gears as regular oil. BUT in a shallow gear set (like my Dana 44) the gears are bathed in oil, and a dry gear is not really an issue.
What are your thought? Please, try and keep opinons to a minumum and only folks with factual evidence one way or another chime in. Any engineers/ mechanics out there?
Thanks,
Ryan
Thanks,
Ryan
