Originally Posted By: BuickGN
Originally Posted By: friendly_jacek
Originally Posted By: ekpolk
And FWIW, the Toyota/Lex hybrids, which in urban driving do far more engine starting and stopping than most cars (mostly hot though) have a specifically programmed-in feature for starting. Motor-Generator-1 (the smaller one that's connected to the center shaft of the PGS) spins the ICE to about 1000 rpms before it orders up fuel and spark. This promotes smooth ICE starts, and ensures that the pump has built oil pressure before the ICE sees real driving loads on critical parts. These cars have neither traditional starters, nor alternators, nor PS pumps. MG1 in effect acts as both a starter motor and an alternator if needed (the inverters normally make plenty of AC drawing from the hefty current and voltage sent from the TB).
Anyway, all this suggests to me that there is legitimate concern about startup wear, even in a warm or hot engine. Why would have Toyota bothered with such systems if not?
You are correct, there is a concern of increased bearing wear in hot (but not cold) engine on restart. It is well explained in this PDF on page 4 under the paragraph Tempereture of the Oil (sorry, could not copy and paste):
http://www.zddplus.com/TechBrief11 - Internal Combustion Engine Lubrication.pdf
So, thicker is sometimes better.
I got the link from this thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1531540&fpart=2
I'm surprised no one commented on this. It clearly shows the relationship between viscosity and protection.
I'm actually not surprised there were no comments. You can call me a cynic.
