Gear Oil
by VintageMonte
05/23/13 11:46 PM
$2 off 5qt jug Havoline High Mileage at Walmart
by robshelton
05/23/13 10:30 PM
Mobil 1 HM or Mobil 1 EP
by c24k
05/23/13 10:17 PM
29 NJ bars accused selling cheap liquor as premium
by Joe1
05/23/13 09:59 PM
Bridge down!!
by Pablo
05/23/13 09:57 PM
Small Problem With Toyota Parts Dept
by Trav
05/23/13 09:57 PM
Had someone else change my oil today! ARG!!
by tig1
05/23/13 09:35 PM
99 Lexus GS400 with only 44k miles - ok to switch?
by fonebone
05/23/13 09:29 PM
Pennzoil Gold Bottle (synthetic blend)
by NorrisB
05/23/13 08:23 PM
What cars use 19mm lug wrench?
by asand1
05/23/13 08:01 PM
Old Fuel, E10
by Whimsey
05/23/13 07:57 PM
PYB What to expect
by Realtech214
05/23/13 07:37 PM
Biggles, mahler206, VintageMonte, runnerbl, slush
45538 Registered Users
31 registered (bilibako2, bama7x57, 190E26FTW, angelivan_sparta, avss1, Bebop), 560 Guests and 231 Spiders online.
45538 Members
64 Forums
193852 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 20 1 2 3 ... 19 20 >
#1470063 - 05/19/09 04:33 PM is Regular oil safe for '03 BMW?
Tobin Offline
Loc: Nanuet, NY (half hr from NYC)
Novice question from a novice oil guy with no mechanical prowess or knowledge--but need advice badly from ppl who know cars and oil!!
I recently inherited a 03 bmw 325i, about 90k miles, car manual recommends 5w30 or 5w40 fully synthetic oil (so far only synthetic oil has been used). What would happen if I added REGULAR 5w30 oil in my car? Will regular oil damage or harm my engine over time. If so, please explain and specify how.
I drive in normal conditions, in a fairly sub-urban area, upstate NY, do not race but do occasional spirited driving.
I have asked several mechanics but all have told me its not a good idea except none of them can explain why or give a clear reason. When I went to the BMW dealer, asking that question to a technician gets them little angry and I got a hurried response, they told me to "do what I like outside at any garage". That was really embarrassing.
To my understanding oil’s main function is to act as a lubricant so why not the use of regular oil in my engine? Or does BMW want consumers buy more expensive materials,be exclusive, that is not completely necessary? As I have read online, in Europe, many car owners do not even use synthetic oil as Americans do but there cars run very long.
Not interested in blending. I also know that synthetic oil is superior to regular oil. I just started working and am paying off student loans and cant afford the $100+ to do an syn.oil change and I dont want to unless I know its completely necessary i.e. damage to the engine, etc.
Advice needed,
Tobin, 23, New York
#1470070 - 05/19/09 04:45 PM Re: Regular oil okay for '03 BMW [Re: Tobin]
Quattro Pete Offline
Loc: Illinoistan
One of the main reasons BMW wants you to use synthetic oil is that they expect you to run longer intervals... 10-15k miles (if you follow the on-board oil change light). A typical mineral oil will not hold up that long. And if you have to change it 2-3 times as often, then is it really cheaper in the long run?
If you're on a budget, then do your own oil changes - 7 quarts of appropriate synthetic oil plus an oil filter will cost you about $50.
Also, one of the requirements for BMW oil is relatively high HT/HS. You will not find a 5w-30 mineral oil that meets it. High HT/HS ensures an oil film is not broken when you're doing your "occasional spirited driving".
I guess it depends who you talk to. All newer cars in Europe run pretty long OCIs - 20k km or every 2 years. Most mineral oils don't hold up well over such long intervals. I'd be surprised if those owners really run mineral oil in their cars.
My parents who live in Europe have cars that are not that young anymore - a '99 Nissan Primera and an '02 Volvo S40. Both those cars call for synthetic oil, and when they go for service, that is exactly what they get.
Edited by Quattro Pete (05/19/09 04:49 PM)
'02 530i (PU 5W-40)
'08 C300 4Matic (M1 0W-40)
'08 Vulcan 500 LTD (SRT 15W-40)
#1470075 - 05/19/09 04:50 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
Trajan Offline
Loc: SE PA
I didn't know that.(The HT/HS). Always used syn oil though in the Z4.
Edited by Trajan (05/19/09 04:50 PM)
2006 Mustang GT. 5w-20 Mobil 1 EP.
#1470077 - 05/19/09 04:50 PM Re: is Regular oil okay for '03 BMW? [Re: Tobin]
JHZR2 Offline
Loc: New Jersey
If you do it yourself, it will not be $100, and you'll be able to recoup the cost by longer drain intervals, if you use a bmw long-life spec oil.
There are a variety of reasons why dino oils are not sufficient, including the requirement for robust hths viscosity - all bmw spec oils are aces a3, and no decent dino oils in the correct viscosity are.
10w-40 dino would be the closest to reasonable protection available in a dino oil, but given the VII requirements, the oil will shear down quick and need to be changed more often.
You might consider running chevron delo in 15w40, or if you can find it, 10w-30 versions of shell rotella or chevron deli, as either will be more robust. None are optimal, and you'll need to change oil far more often than if going with syn.
I'd pick the right oil - I'd use m1 0w-40, use the oil life monitor to it's fullest extent, and do what is right for the car.
#1470078 - 05/19/09 04:51 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
Tobin Offline
What is HT/HS stand for? and when this film is broken what happens next?
I will definetly have to look into learning to do an oil change if i understand why synthetic oil is required lol
In Europe and Asia I read some BMW owners use regular oil but they do not wait 10 to 15k intervals to do an oil change.
#1470082 - 05/19/09 04:54 PM Re: Regular oil okay for '03 BMW [Re: Tobin]
Loc: Illinoistan
HT/HS - high temp / high shear stability. When the oil film is broken, two pieces of metal come in direct contact with each other - this causes excessive engine wear.
'02 530i (PU 5W-40)
#1470083 - 05/19/09 04:55 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
daves87rs Offline
Loc: Michigan
My sister in law tried running dino in her BMW...and with her driving, it really was a big no-no.
I'm guessing you could (she did for nearly 1500 miles-didn't hurt the car), but with the crazy weather in the northeast, and city driving, I would put synthetic in it, even if it had to be wal mart oil...
"Coming together is a beginning; keeping together is progress; working together is success."-Henry Ford
#1470088 - 05/19/09 05:00 PM Re: Regular oil okay for '03 BMW [Re: daves87rs]
Zaedock Offline
Loc: Massachusetts
IMO, a 15W40 HDEO (like Delo) would hold up.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#1470089 - 05/19/09 05:01 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
Tobin Offline
Ohh I see, so your saying my BMW engine gets unusually hot during spirited driving..causing the film to wear out during this type driving?
So does that mean the BMW engine gets hotter than a Nissan sentra if you compared both engines during spirited driving?
#1470090 - 05/19/09 05:01 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
Jaymus Offline
Loc: Tennessee
I agree with Pete. BTW, how can I find the HTHS of oils?
#1470095 - 05/19/09 05:05 PM Re: is Regular oil okay for '03 BMW? [Re: JHZR2]
Tobin Offline
To JHZR2
You said 10w-40 dino would be the closest to reasonable protection available for REGULAR oil...but your saying it requires more changes because it cannot hold up in shearing.
So is changing the oil every 5k miles a good rule of thumb for this grade of oil in my car?
#1470100 - 05/19/09 05:11 PM Re: Regular oil okay for '03 BMW [Re: Quattro Pete]
Tobin Offline
QOUTE from QAUTTRO PETE--->Also, one of the requirements for BMW oil is relatively high HT/HS. You will not find a 5w-30 mineral oil that meets it. High HT/HS ensures an oil film is not broken when you're doing your "occasional spirited driving".
Edited by Tobin (05/19/09 05:18 PM)
#1470111 - 05/19/09 05:27 PM Re: Regular oil okay for '03 BMW [Re: Tobin]
Loc: Illinoistan
Maybe not necessarily hotter than a Nissan Sentra engine, but BMW engines have typically high output and the construction is such that it puts the oil through some serious paces, so you want an oil that is very stable and still doing its job under those conditions. Then again, I am not a BMW engineer, so I cannot tell you how they determined that an HT/HS of 3.5 is good, but 3.4 is already insufficient.
Forget the HT/HS. Focus on the drain interval - you can go twice as long on synthetic than on mineral, so you're saving time and labor costs. Wouldn't that in itself make a good argument for using synthetic oil?
Are you also not running premium gas in it?
'02 530i (PU 5W-40)
#1470113 - 05/19/09 05:28 PM Re: Regular oil okay for '03 BMW [Re: Jaymus]
Loc: Illinoistan
Some companies show it in their literature (PDS) on their websites. Some don't. I have yet to find out HT/HS for the new Castrol Edge stuff.
'02 530i (PU 5W-40)
#1470116 - 05/19/09 05:33 PM Re: Regular oil okay for '03 BMW [Re: Tobin]
Trajan Offline
Loc: SE PA
I kinda think that changing oil every 5k using dino vs every 15k using syn is going to end up costing you more.
Stick with the syn, especially if you are going to do spirited driving.
