Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
20 registered (Duffyjr, c502cid, bbhero, Duke, 2 invisible), 459 Guests and 102 Spiders online.
58001 Members
66 Forums
249545 Topics
Page 1 of 2 1 2 >
#1414079 - 03/25/09 02:09 AM Cadillac Catera, burns oil, reccomendations?
L33tA2 Offline
Loc: Suffolk County, NY
I have a 2001 Cadillac Catera that just ticked over to 127k miles. I've had the car for 6 months now and have put about 9k miles on it in that time. It has the GM L81 3.0 V6 also found in various Saab and Saturn models and the 03-04 CTS has a 3.2L variant. The first oil change I did was somewhat scary. I don't think the filter had been changed in ages and the oil was black. I bought the car at a repo auction for cheap and only had 30 seconds to look it over before buying. It has treated me well, but one problem I can't seem to get rid of is the oil burning. The car doesn't leak more than one drop per week. There is a nice puff of blue smoke to remind me every morning. I "change" the 6qts of oil every 3k miles, but in that time I add roughly 3qts to keep it topped up. The car has plenty of power, doesn't hesitate, foul plugs, or have any real running issues I would normally associate with burning oil. It just irritates me that I need what turns out to be 9 quarts of oil over every OCI.
Does anyone have any recommendations? I read something about Auto-Rx but I'm not sure what do do. So far I have gotten the consumption down, from eating about 4qts to "only" 3, by switching to a High Mileage oil.
'98 Ford Ranger XLT 4.0 OHV V6 4x4 - Lifted on 265/75/16 - M1HM 5w30
'87 Volkswagen GTI 1.8L 8v Turbo - Slammed on 185/60/14 - M1 15w50
#1414089 - 03/25/09 02:30 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: L33tA2]
jldcol Offline
Loc: ohio
So a qt. per 1k miles, yeah that's a lot. I think the morning blue puff is a sign of valve stem seal leakage. Has the use been the same, or is going up? You can use the miracle drug ARX, a metal cleaner it seems, but thats better on the ring pack I think don't see it much use on a worn valve seal. You should compression/leak down test it and see better where problem is. If rings can clean at some risk, may get better and may get worse. Hopefully is was cheap enough to allow for some reserve to buy make up oil.
Sorry if unclear, I intended to make no sense at all.
#1414091 - 03/25/09 02:32 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: L33tA2]
wirelessF Offline
Loc: Oahu, Hawaii
What oil brand and weight are you using? Switching to a heavier, high milage oil might reduce the oil burning.
#1414146 - 03/25/09 06:52 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: wirelessF]
[email protected] Offline
Loc: Michigan
You need to put oil burning on the back burner for a second...
I have a 2005 Saturn L300 and had a 2000 LS, both with the same 3.0l engine (albeit some intake changes).
The engine is an intereference engine and is VERY finicky with timing belts. The timing belt must be changed around 100,000 times or you are on borrowed time. At that time, the water pump and tensioners are changed.
I would take the timing belt cover over and see if that belt has ever been replaced. If not, that'd be my priority.
Other than that, we have logged over 130,000 miles on the 3.0l engine. Aside from oil coolers, regular maintenace (run valvoline syn in ours), its a great engine. Great mpg's and lots of power.
'16 F150, 2.7EB
'16 F150, 2.7EB
Yes, I own 2 '16 F150s."Thanks Dad!" 1936-2015
97 FW Vista 278
T-4.3Gi 185hr&
4kw genset 17hr- T5
#1414152 - 03/25/09 07:11 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: [email protected]]
OMCWankel Offline
Loc: Florida
You might consider using a HDEO in this engine. Rotella T synthetic 5W40 is a good choice, as it is also certified for gas engines. HDEO's have a proven record on this board of reducing oil consumption.
1997 Miata M1 0W40
2004 Mini Cooper S M1 0W40
2014 Ford Fiesta 1.6L M1 0W30
2000 Moto Guzzi Jackal RT 15W40
2000 Ducati ST4 RT 15W40
#1414193 - 03/25/09 08:22 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: OMCWankel]
Eddie Offline
Loc: Florida, Cape Coral
+1 on the timing belt. If one breaks, you will trash the engine.
CX5 Touring 2.5L :-)
#1414217 - 03/25/09 08:52 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: Eddie]
daves87rs Offline
Loc: Michigan
+2
Whatever you are, be a good one.
#1414241 - 03/25/09 09:16 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: daves87rs]
tig1 Offline
Loc: Illinois
Caddy's seam to have an oil burning problem.
http://caddyedge.com/CadForums/viewtopic.php?t=492
Edited by tig1 (03/25/09 09:17 AM)
2007 Ford Fusion 181,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1416293 - 03/27/09 01:17 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: tig1]
L33tA2 Offline
Wow, thanks for all the responses.
Initially I had no idea it was drinking oil like crazy. I picked up the car for $1400 and knew it needed some minor cleaning and tune up. Changed the oil and filter, used Walmart Supertech full synthetic 10w-30, and a WIX filter element. Within 3 weeks the low oil level indicator came on and I checked, sure enough it was about 1qt low, just under the min level on the dipstick. During the first 3k miles it needed 4 quarts added to it. At this point, with my next change coming up, I'm going to be at just over 2.5 quarts added. I have been using Castrol GTX High Mileage since this last change. So far it seems the oil consumption is slowing down a bit.
I used the Castrol GTX High Mileage 10w-30 this last interval and it does seem to be helping with reducing the oil burning. It also may be that I am a pretty enthusiastic driver and at least once a day I open it up and blow that carbon buildup outta there, and I make sure to change the oil regularly.
The engine is an interference engine and is VERY finicky with timing belts. The timing belt must be changed around 100,000 times or you are on borrowed time. At that time, the water pump and tensioners are changed.
Thank you for the advice, I have been on a Catera forum on and off for a few months and learned about the timing belt issues that plagued the 97-98 models which gave the Catera such a bad reputation. From what I had heard though was that the change interval had been reduced to 40k miles and that the original interval was 60k, 100k was madness, am I wrong here? It could also have something to do with the belt routing on the earlier models, they often suggest replacing the bracket that the idler pulleys attach to... I have no idea when mine was done last, if at all, and I have an appointment this week to have my mechanic change the belt, pulleys, water pump, etc.
What may I ask is an HDEO ?
Thanks for the link, they seemed to be talking mostly about the Northstar engine, which is of a different design and construction.
#1432916 - 04/12/09 10:04 PM Re: Cadillac Catera, burns oil, reccomendations? [Re: L33tA2]
L33tA2 Offline
Just ordered up some Auto-Rx, we'll see what happens. I'll take some pics down in the oil filler for some before and after just for fun.
#1432977 - 04/12/09 11:36 PM Re: Cadillac Catera, burns oil, reccomendations? [Re: L33tA2]
bobfather99 Offline
Loc: Northwest Indiana
Just to answer a previous question, an HDEO(heavy duty engine oil) is a "fleet" oil, commonly used in mixed gas/diesel fleets.
Common HDEOs are Shell Rotella, Chevron Delo, Mobil Delvac, Valvoline Premium Blue, etc.
You can use the HDEOs with the A-rx youve bought. Just follow the directions on the A-rx bottle, and hopefully it will help your problem.
05 Chrysler Town and Country 160,030 miles
Current fill, Peak conventional 5w30, Mopar filter
#1432979 - 04/12/09 11:43 PM Re: Cadillac Catera, burns oil, reccomendations? [Re: bobfather99]
Nickdfresh Offline
Loc: Buffalo, NY
I'd up the weight of the HM oil to a 10W-40 or even 20W-50 in the summer. I'd also try MaxLife as some have claimed their burners used less of it than Castrol HM...
And you can also use conventional HDEO (diesel rated oil) like Rotella or Chevron in the 15W-40 weight...
Edited by Nickdfresh (04/12/09 11:44 PM)
#1433314 - 04/13/09 11:39 AM Re: Cadillac Catera, burns oil, reccomendations? [Re: L33tA2]
The Critic Offline
Loc: Walnut Creek, CA
Chances are, Auto-RX isn't going to help with the oil consumption. It may clean up the engine, but it won't do much to address the oil consumption.
You're best bet is to have the problem properly diagnosed and repaired. As the others have mentioned, you may need new valve stem seals. Using an additive to correct a mechanical problem has never worked for me, personally.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1433428 - 04/13/09 01:17 PM Re: Cadillac Catera, burns oil, reccomendations? [Re: The Critic]
PT1 Offline
Loc: near the mistake
Run the ARX per directions and watch your oil filter because it may fill up with gunk quickly. Do the rinse then try Valvoline Max-Life Syn blend (Walmart) for 2 changes and see if it slows the consumption.
Oils well that ends well...
#1433517 - 04/13/09 02:23 PM Re: Cadillac Catera, burns oil, reccomendations? [Re: Nickdfresh]
lewdwig Offline
Loc: Southwest Michigan
+1
1996 Saturn SL2
2001 Saturn SL2
2001 Subaru Forester L
2004 Mitsu Endeavor
Google search:
(search terms here) site:bobistheoilguy.com
Page 1 of 2 1 2 >
