Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
Castrol magnatec
by ChadW
06/25/16 04:07 PM
Purolator Red 14612 Weedeater Size 6k miles
by bbhero
06/25/16 04:05 PM
by bbhero
06/25/16 03:46 PM
2001 Chrysler Concorde selling for cheap.
by chryslerconcorde
06/25/16 03:24 PM
How to open please?
by dblshock
06/25/16 03:19 PM
Do Purolator clone filters have tearing issues?
by jongies3
06/25/16 02:59 PM
BW-44-44 Transfer Case special fluid
by -SyN-
06/25/16 02:27 PM
mini inspection camera for androi phone
by bmwjohn
06/25/16 02:15 PM
Cause of noisey serpentine belt
by 007
06/25/16 01:48 PM
Purolator Boss 14610 C and p
by bbhero
06/25/16 01:33 PM
Ear hair - remove, ignore, trim ???
by Mr Nice
06/25/16 01:04 PM
machfive916, Pollybaby, bigblue9, Kane304, 69er
58266 Registered Users
80 registered (austinlunsford, Al, 2002 Maxima SE, Astro14, AZjeff, 12 invisible), 1911 Guests and 11 Spiders online.
58266 Members
66 Forums
250806 Topics
#1405439 - 03/16/09 09:35 PM 5w30 vs 10w30
05Blazer Offline
Loc: Illinois
I have switched my young 4.3L Blazer that sees fleet use to Maxlife Blend and have been very happy with the quietness of the engine and slowing of the cooler line leaks. I have always used 5w30 as per the owners manual & I am about to do an oil change for the summer and am wondering if I will see any benefit by switching to 10w30. After looking at the product specs on Valvoline's website they seem to have near matching numbers in every category except the 5W30 has a higher Viscosity Index rating of 163 vs. 10W30 146. This leads me to believe that the 5W30 might actually even be better period. Your thoughts?
thanks
12 GMC Yukon SLT 4WD 5.3L 8K
Mobil1 EP 5W30 AC DELCO PF48
11 Honda Pilot EX 4WD 3.5L 20k
Penn Plat 0W20 OEM filter
#1405458 - 03/16/09 09:52 PM Re: 5w30 vs 10w30 [Re: 05Blazer]
wannafbody Offline
Loc: PA
Theoretically the 5w should be better than a 10w at startup.
2000 TA WS6
#1405508 - 03/16/09 10:46 PM Re: 5w30 vs 10w30 [Re: wannafbody]
FrankN4 Offline
Loc: Kentucky
You can only compare the VI of the same grade, XW-X to XW-X. You could not compare the VI of a 5W-30 to a 10W-30.
Check out this thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1399421&fpart=1
Actually, I never was as good as I used to be.
#1405515 - 03/16/09 10:56 PM Re: 5w30 vs 10w30 [Re: wannafbody]
TallPaul Offline
Loc: By Detroit
Viscosity index is meaningless unless you know the base oil and amount of viscosity index improver (VII) in the oil. An oil could have a very high VII and low grade base oil if enough VII is added, but would not necessarily be better than say a straight 30 which has no VII and a much lower viscosity index.
All else equal, there would be less VII in the 10w30, but many times all else is not equal. Two oils of the same brand may have some measure of better quality base oil in the 5w30 to make up for the wider spread, that is, so much Group III could be added to the 5w30 so the VII would not have to be boosted as much.
But I would run the 10w30 in summer since you don't need extreme cold starting properties.
#1405531 - 03/16/09 11:14 PM Re: 5w30 vs 10w30 [Re: TallPaul]
Peter_Pan Offline
Loc: CA
One thing I've noticed consistantly when reading the data sheets for oils is that 10W-30 has a lower NOACK and higher density compared to 5W-30 which is expected more or less due to the differing amounts of VII added and his translates in to a more stable oil IMO. All said and done though, the difference is very small and you may not even feel a difference at all.
I agree with Paul, 10W-30 is a very good choice whenever temperatures are above 20-30 F.
08 Merc E350 4MATIC 3.5 M272
07 Mercedes Benz C280 4MATIC 3.0 M272
09 Craftsman YTS4500 0.750 B&S V-Twin 24HP XRD
#1405680 - 03/17/09 07:36 AM Re: 5w30 vs 10w30 [Re: Peter_Pan]
Nickdfresh Offline
Loc: Buffalo, NY
Both 5W-30 and 10W-30 MaxLife have a -42F pour point, so I doubt you'll notice much difference even in cold weather at start-up...
I would use the 10W-30 if doing a lot of highway driving since it will not sheer as much. Although, the 5W-30 ML is pretty "thick" at temperature so sheering is probably irrelevant...
#1405693 - 03/17/09 07:55 AM Re: 5w30 vs 10w30 [Re: Nickdfresh]
TallPaul Offline
Loc: By Detroit
Yes Peter Pan, NOACK is an excellent parameter to compare oils on.
I should clarify, viscosity index (VI) is largely based on the inherent VI of the base oil and the amount (and type) of viscosity index improver added (VII). So you never know how much of the VI is due to the quality of the base oil vs loads of VII being added. That's why I totally ignore VI as a parameter for evaluating/comparing oils.
#1405694 - 03/17/09 07:58 AM Re: 5w30 vs 10w30 [Re: TallPaul]
addyguy Offline
Loc: Canada
I'd run the 10W-30 during the summer. A touch thicker at lower temps, and may burn/leak a bit less.
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
