1999 Honda ST1100
Water-cooled V4
Shared engine/trans. oil, wet clutch
Comments:
Mobil Delvac 15W40 oil
PL14612 is a Purolator automotive oil filter
LC20 used in the oil. FP3000 and Redline Lead Substitute in the gas.
I'm not too worried about the Sodium, it is not coolant. I am using Redline Lead Substitute
in the fuel to help protect the valves and it is Sodium-based. I have used it before and it
shows up in the oil tests.
This is the second run on Delvac. Low wear numbers and pretty good viscosity. The Iron reading is down again.
Blackstone Labs Test results:
Oil...............Rotella 15W40 CJ4 ....Max Life 10W40....Delvac 15W40....Delvac 15W40
Filter............1536 Napa Gold....1536 Napa Gold....PL14612 Purolator....PL14612
Total Miles....89,028.................97,045................110,996................119,028
Miles on oil....7,947..................8,017.................8,016...................8,062
Time on Oil.....3 Mo.....................5 Mo...................2 1/2 Mo............3 1/2 Mo
Make up oil......0.....................0.......................0..........................0
Aluminum.........13...................9...................8...........................10
Chromium.........1.....................0....................1.........................1
Iron................24........................23...................14....................14
Copper............3.........................3....................3.....................3
Lead...............4........................3....................3......................3
Tin.................0.......................0....................1......................0
Moly..............8..........................249..................82....................51
Nickel.............0........................0....................0.....................0
Manganese......0.......................0.....................0......................0
Silver..............0.........................0....................0.....................0
Titanium..........0.......................0....................0......................0
Potassium........7.......................2....................2.......................2
Boron.............32......................13...................37.....................27
Silicon.............12.......................12...................12....................11
Sodium.............19........................10....................332....................343
Calcium............2347......................2588....................1719.................1169
Magnesium.........17..........................9.......................827...................735
Phosphorus.......956........................742........................963...................806
Zinc.................1264....................863........................1300...................1018
Barium.............0.......................0..........................0........................0
Flashpoint F......400.....................385........................410.......................385
Fuel................ Antifreeze........0............................0......................... .66........................ ??
Water.............0........................0..........................0...........................0
Insoluables......0.2.......................0.2........................0.3........................0.3
SUS Visc@210f..71.5......................61.5........................68.4......................66.0
cST Visc@100c..13.35...................10.64.......................12.54.......................11.89
TBN.................4.2...................3.1.........................3.1........................4.2
Water-cooled V4
Comments:
