My wife's car: For now, all 3 previous oil changes have been done by the dealer when the maintenance minder was between 5 and 0%, meaning about 8.000kms OCI (5000 miles) and about 8 to 9 months.
90% city driving, stop and go, short trips to daycare and work (less than 20 minutes). From december to june 20 (canadian winter in a garage at night
). My wife is not too hard on the throttle, knows you have to warn up the engine and so on. She has knowledge in mechanics as she has an aeronautical degree.
This sample was between 30 and 20% MM (30% indicated when sampled but moved to 20% few days later).
Oil filter is honda filter.
Air filter was the same from the beginning (changed it when I sampled).
As contrary as said in the owner manual, the dealer said he changed the oil filter at each oil change instead of every two oil changes
. Supposed to be Mobil1 conventional.
I did not changed the oil as I wanted to see the results first and wanted to know what was the next maintenance program (been told since it will be a B2 maintenance).
Plan to put Castrol Syntec 5w20 when I or dealer (still fighting my wife on that
) will change oil with Eao13 filter in order to sleep better at night and go to the 0% MM without any worry (will still do an UOA between 40 and 30%).
I am very impressed how this engine behaved even without any care from its owners (me).
Any comments?
Could someone explain to me the Nitration level and what does it mean?
Should I change the oil now or wait to go down to about 5% as usual (it is summer now
Any comments?
