Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
BlueKelah, threeeightteen, TOADchunks, Longo9596, Roadrunner77z
56889 Registered Users
25 registered (bmod305, bbhero, B320i, BlueKelah, 3 invisible), 517 Guests and 195 Spiders online.
56889 Members
66 Forums
244532 Topics
Page 1 of 2 1 2 >
#1099933 - 03/06/08 08:26 AM 96-98 chevy lumina coolant leak question
mikeg5 Offline
Loc: north carolina
hey guys my lil brother who is going to school up in Buffalo, NY has a coolant leak and cant figure out what is going on. here is the story..
he is adding a resevoir's worth of anitfreeze (dexcool) every 3-5 days.. here in NC the leak was much less but up there since (what he thinks) is since he has to run the heat so much he is noticing it leaking more. he doesnt know squat about cars... i told him to look for it leaking on the ground and let me know something...
he says it really leaks when the defrost is on (when thermo is on hot) to me that doesnt make sense.. can anyone chime in on this? he is 12 hours away and he doesnt have time nor the $ to have someone look at it. thanks guys
02 Toyota Tacoma 4 door 3.4 v6 4X4
150k miles. Amsoil in the diffies and tranny
05 Corrola LE 145k miles auto
#1099934 - 03/06/08 08:27 AM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
mikeg5 Offline
Loc: north carolina
btw he just had (before he left NC back in july of 2007) his radiator flushed and etc.. i double checked it when he left and all was well.
#1099967 - 03/06/08 09:09 AM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
WishIhadatruck Offline
Loc: Grand Rapids, MI
If it isn't leaking on the ground, it could be leaking internally. Is there a white cloud from the exhaust or is the oil way over full? That is a large leak if he is losing that much.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
#1099976 - 03/06/08 09:24 AM Re: 96-98 chevy lumina coolant leak question [Re: WishIhadatruck]
Drew99GT Offline
Loc: Colorado Springs
96-98 Lumina? 3.1L?
INTAKE MANIFOLD GASKETs!
#1099978 - 03/06/08 09:27 AM Re: 96-98 chevy lumina coolant leak question [Re: Drew99GT]
mikeg5 Offline
Loc: north carolina
i was afaid of the intake manifold gaskets.. how much is that to fix??
he is going to get back to me about finding leaks under the car, there is snow on the ground so it should be obvious if it is leaking externally.
#1100063 - 03/06/08 11:44 AM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
Drew99GT Offline
It'll cost between $500 to $800 depending. Make sure you purchase problem solver gaskets by fel pro.
Things to check: look under the oil cap fore signs of moisture - a white pinkish milky glop. Also, shine a flashlight into the oil filler and look at the oil on top of the head - it'll likely have that same moisture/antifreeze laden look (a reservoir's worth of coolant loss every week is a ton!). Also, they leak externally - shine a flashlight around the area under the thermostat housing - you'll likely see antifreeze.
Get it done ASAP! In fact, I wouldn't drive the car. That's a big leak and is likely to do damage to the motor.
Good luck!
#1100064 - 03/06/08 11:44 AM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
Squishy Offline
Loc: Orillia, Ontario
If it really is related to heat and not just in his head, you could be looking at a leaking heater core. Usually accompanied by a wet carpet.
96 Pontiac Trans Sport
99 Ford Escort
01 Acura MDX
03 Mitsubishi Lancer
03 Ford Escape
#1100076 - 03/06/08 12:10 PM Re: 96-98 chevy lumina coolant leak question [Re: Squishy]
Drew99GT Offline
If it was leaking a couple pints a week through the heater core, it would stink of antifreeze in the cabin and the windows would be foggy I think.
#1100275 - 03/06/08 04:56 PM Re: 96-98 chevy lumina coolant leak question [Re: Drew99GT]
onion Offline
Loc: kansastan
Likely it's intake gaskets. +1 on everything Drew said.
Have him check for coolant in the oil. If there's any sign, he'd better quit driving it NOW. Coolant in the oil can take out bearings real quick.
The invisible and the imaginary look exactly the same.
#1100605 - 03/07/08 07:58 AM Re: 96-98 chevy lumina coolant leak question [Re: Squishy]
mikeg5 Offline
Loc: north carolina
thats not it, you would smell it too and i asked him about that and he said no
#1100617 - 03/07/08 08:08 AM Re: 96-98 chevy lumina coolant leak question [Re: Drew99GT]
mikeg5 Offline
Loc: north carolina
Good luck!
thanks man i relayed the message to him but he is flying back here (NC) this evening and wont have time to check he car till next week when he goes back to Buffalo... ill get back to this when i find out more... here i thought that car was a good one.. leave it to american made vehicles to be [censored]. argh
#1100645 - 03/07/08 08:54 AM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
Chris142 Offline
Loc: apple valley, ca
I have never seen an intake manifold leak that much coolant. Usually it's just a small seep. I'm betting on a hose, water pump or worse.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1100724 - 03/07/08 11:08 AM Re: 96-98 chevy lumina coolant leak question [Re: Chris142]
mikeg5 Offline
Loc: north carolina
chris, this is what i am hoping on. the upper and lower hose were supposed to have been replaced before leaving. along with the water pump. as a matter of fact ill call the chevy place that my parents used to work on his car before he left.
OH btw he said he knew when his coolant was geting low bc his gas mileage would start to suck.. if that helps any
#1100753 - 03/07/08 12:05 PM Re: 96-98 chevy lumina coolant leak question [Re: mikeg5]
dwendt44 Offline
Loc: Central Wisconsin
Some GMs have three other hoses coming off the engine.
Heater hoses of course, but I've got a small hose as well
(bleed) that I replaced a while back.
The radiator itself could have a small leakage as well; only leaking when at speed. BTDT too.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1100801 - 03/07/08 01:12 PM Re: 96-98 chevy lumina coolant leak question [Re: dwendt44]
mikeg5 Offline
Loc: north carolina
the only thing that was done at the shop before he went to buffalo was a coolant flush and the upper and lower radiator hose replaced. thats it
Page 1 of 2 1 2 >
