F1 - 2016 Monaco Grand Prix
by gofast182
15 minutes 59 seconds ago
Mazda 3 drain and fill
by jay929
17 minutes 9 seconds ago
Looking at VW TDI
by loneryder
41 minutes 40 seconds ago
Valvoline Maxlife ATF & Walmart
by HosteenJorje
54 minutes 38 seconds ago
New car polish
by Tempest
56 minutes 42 seconds ago
Toyota Red long Life vs Pink Super Long Life?
by Drew99GT
Today at 10:50 AM
Extended Warranty Requirement
by TiredTrucker
Today at 09:57 AM
RARE HID installation
by Kira
Today at 08:51 AM
ATP AT-205 good engine cleaner ?
by kr_bitog
Today at 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
Today at 01:43 AM
Quicksilver Prem Plus
by jmw116
Today at 01:39 AM
Creating white letter tires
by turtlevette
Today at 12:22 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
82 registered (AKA, 1JZ_E46, Andrei, ARCOgraphite, 97f150, 440Magnum, 9 invisible), 1789 Guests and 318 Spiders online.
57973 Members
66 Forums
249383 Topics
Page 1 of 2 1 2 >
#1078946 - 02/04/08 02:17 PM Car batteries freeze??
Russell Offline
Loc: Lexington, KY
Anyone heard of a car battery freezing? My daughter lives in Wasausa(sp), WI and the temp was about -19 and with a wind chill of about -40 or so and one of her friends had a battery freeze and crack. How does this happen and what should be done to prevent it?
Edited by Russell (02/04/08 02:18 PM)
Russell Casey
1995 BMW 525i M50TU 2.5L-6, abt 236K miles. Rebuilt trany.
1998 Ford Explorer Eddie Bauer 154k miles, 4L-SOHC V6. timing chains replaced
#1078964 - 02/04/08 02:35 PM Re: Car batteries freeze?? [Re: Russell]
ShiningArcanine Offline
Loc: New York
Considering the freezing points of sulfuric acid (283 Kelvin) and water (273 Kelvin), I would expect that the ions are the only things keeping the battery from freezing. I cannot say for certain, but it is possible that lead acid batteries could freeze when the temperature drops to 254 Kelvin.
A possible solution could be to use a different battery chemistry. Lithium Ion batteries freeze at 233 Kelvin, but they lose their capacity as a function of time and the ambient temperature. Given how hot it can be in the hood of a car, Lithium Ion batteries are probably not a good choice. There are other chemistries that are avaliable, which you can read about on wikipedia.
Another possible solution would be to insulate the battery, although a potential problem with that would be that the maximum temperature that it would encounter during the summer would be increased, so partially insulating it might be preferable.
#1078966 - 02/04/08 02:40 PM Re: Car batteries freeze?? [Re: ShiningArcanine]
rpn453 Offline
Loc: Saskatchewan
Yep, discharged batteries will freeze. A friend of mine left something on in his truck at the park-and-fly last week and needed two new batteries for his truck when he got back.
2004 Mazda3 GT Hatch 75k
#1079004 - 02/04/08 03:49 PM Re: Car batteries freeze?? [Re: rpn453]
brianl703 Offline
Loc: Manassas, VA
Keep the battery charged. If it's not possible to drive the car on a regular basis or to connect an AC powered charger, you can get a solar charger from Harbor Freight:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44768
This will do a fine job of keeping the battery charged.
This is assuming that something wasn't left on to cause the battery to discharge. The above solar charger will compensate for the vehicle's parasitic draw and for the battery's self discharge. It can't compensate, for example, if someone leaves a cellphone charger plugged in.
At 100% charge, a battery will freeze at -77F. At 75%, -35F. At 50%, 10F. At 25%, 5F. At 0% (totally discharged), 20F.
Edited by brianl703 (02/04/08 03:52 PM)
#1079011 - 02/04/08 03:54 PM Re: Car batteries freeze?? [Re: ShiningArcanine]
brianl703 Offline
Loc: Manassas, VA
As a matter of fact, many manufacturers install battery insulators to protect them from engine heat. It's not going to do anything to keep a battery from freezing though--the battery which is sitting idle isn't producing any heat at all. Which is why the wind chill doesn't matter here.
#1079077 - 02/04/08 05:04 PM Re: Car batteries freeze?? [Re: ShiningArcanine]
swalve Offline
Loc: Chicago, IL
For those of us who don't think in Kelvin, those temps are:
283 kelvin = 49.73 degrees Fahrenheit
273 kelvin = 31.73 degrees Fahrenheit
254 kelvin = -2.47 degrees Fahrenheit
How did you determine that 254 K was the potential freezing point?
#1079082 - 02/04/08 05:09 PM Re: Car batteries freeze?? [Re: brianl703]
swalve Offline
Loc: Chicago, IL
In a marginal case, it can. Insulation slows the flow of heat both ways, so it depends on the R value of the insulation, the time and temperature. If the car is sitting for a month, it won't make a difference. But it might be enough to prevent freezing overnight.
#1079085 - 02/04/08 05:12 PM Re: Car batteries freeze?? [Re: swalve]
brianl703 Offline
Loc: Manassas, VA
Yea, but if the charge on that battery is dropping overnight to the point where freezing is a problem, there are problems that a battery insulator still isn't going to help--either a faulty battery or a parasitic load or a faulty alternator.
Edited by brianl703 (02/04/08 05:13 PM)
#1079144 - 02/04/08 06:30 PM Re: Car batteries freeze?? [Re: brianl703]
John K Offline
Loc: Loveland, Ohio
brianl703 - I knew that a discharged battery could freeze, but I am curious about where you got the data of the %charge vs FP?
#1079208 - 02/04/08 07:35 PM Re: Car batteries freeze?? [Re: swalve]
Loc: New York
The original poster said that the ambient temperature was 19 degrees below zero when the battery had broken, although in hindsight, it would have been better to say 250 kelvin to take into account significant figures.
#1079261 - 02/04/08 08:16 PM Re: Car batteries freeze?? [Re: ShiningArcanine]
brianl703 Offline
Loc: Manassas, VA
I got it here:
http://jgdarden.com/batteryfaq/carfaq4.htm#freeze_points
I made a typo on the 50% charge level freeze point--should be -10F not 10F.
#1079488 - 02/05/08 06:57 AM Re: Car batteries freeze?? [Re: brianl703]
John K Offline
Loc: Loveland, Ohio
Thanks Brian. That is an interesting web site! If you go to the home portion (jgdarden.com) it is a photographer's site. Confusing to me (the site), but very interesting. Lots of info on batteries.
#1079669 - 02/05/08 11:58 AM Re: Car batteries freeze?? [Re: John K]
NYEngineer Offline
Loc: NY, NY
Years ago, I was a mechanic at a big boat yard. In the winter, we removed the batteries from all the boats and placed them on shelves in a well ventilated shed all paralled to a few automatic chargers. My boss told me that as long as we kept them charged, they would not freeze. I guess he was right because for two years I worked there, we never lost a battery.
#1079939 - 02/05/08 06:17 PM Re: Car batteries freeze?? [Re: NYEngineer]
Gary Allan Offline
Loc: Pottstown, PA
When it's discharged ..it's mostly water ..as everyone sorta said. That's why you typically can't recover a battery that's been idle for too long in a freezing environment, even if it was new when idled. The freezing, even if it doesn't break the case, screws up the plates and connections.
http://lube-direct.com/gallan/
#1079956 - 02/05/08 06:48 PM Re: Car batteries freeze?? [Re: Gary Allan]
Russell Offline
Loc: Lexington, KY
Thanks, this is almost more than I wanted to know. :)
Russell Casey
Page 1 of 2 1 2 >
