New old ride
by SEBZX79
Yesterday at 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
Yesterday at 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
Yesterday at 10:38 PM
Cosmetic only or replace
by ram_man
Yesterday at 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
Yesterday at 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
Yesterday at 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
Yesterday at 08:39 PM
Delo 400?
by Sealbilly
Yesterday at 07:17 PM
Noob question about chain maintenance
by JeepWJ19
Yesterday at 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
Yesterday at 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
Yesterday at 05:08 PM
sears SYWR $30 off $30 surprise
by eljefino
Yesterday at 05:03 PM
dewpoint, Luuey, Eskimio, Jngoose76, Ken_Clifton
58593 Registered Users
22 registered (Brad_C, autoguru_24, alcyon, AMC, 2 invisible), 940 Guests and 15 Spiders online.
58593 Members
66 Forums
252249 Topics
Page 1 of 2 1 2 >
#1000045 - 09/30/07 07:40 AM Head gasket blown in 3800 series II motor
Drew_Shev Offline
Loc: MA
As I was driving home from advanced auto parts today the head gasket blew out on my 96 Pontiac Bonneville. I'm 90% sure it was that due to the smoke out of the exhaust plus the smell right before it blew. I was at AA to get a code checked out, it was "multiple cylinder misfire" if I remember correctly, which would probably make sense. Now to put this into perspective I'm a 17 year old that lives by himself with a good selection of tools, I'm pretty mechanically inclined but I don't have a lot of money and I know getting it repaired won't be cheap. So I would like to know how hard it is to replace the head gasket on these motors. Thanks.
#1000046 - 09/30/07 07:44 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Drew_Shev Offline
Loc: MA
I don't know if this info is valuable at all but about 20 min before the head gasket went out the heat was not working. Could that point to a bad thermostat also?
#1000047 - 09/30/07 08:03 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
It's probably not the head gasket! These engines have a lower intake manifold gasket that will give way and flood the cylinders with engine coolant; in effect showing the same symptoms as a blown head gasket on other types of engines.
The new and improved AC Delco gaskets have strips of aluminium sandwiching the the bolt holes; thereby totally preventing another failure!
I'll be back with more info shortly.
#1000048 - 09/30/07 08:04 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
AcuraTech Offline
Loc: St. Paul, MN
The heat probably wasn't working because there wasn't any more anti-freeze in the cooling system. Does this car have a temperature gauge? Did the car overheat at all? Usually overheating is what causes head gaskets to blow. Are there any coolant leaks anywhere? The 3.8 engine is generally very reliable and not prone to head gasket failure, but any engine will blow a head gasket if it gets hot enough.
If I were you I would buy a repair manual for your car, look at the procedure to remove the cylinder heads, and see if it's something that you would feel comfortable doing.
*The above post is not to be construed as professional advice. For entertainment purposes only.*
#1000049 - 09/30/07 08:07 AM Re: Head gasket blown in 3800 series II motor [Re: AcuraTech]
AcuraTech Offline
Loc: St. Paul, MN
Whoops nevermind. I forgot about the intake gaskets going bad on these. Listen to Merkava!
#1000050 - 09/30/07 08:10 AM Re: Head gasket blown in 3800 series II motor [Re: AcuraTech]
Drew_Shev Offline
Loc: MA
The temp gauge was fine. But I don't know how accurate they are.
#1000051 - 09/30/07 08:16 AM Re: Head gasket blown in 3800 series II motor [Re: Merkava_4]
Drew_Shev Offline
Loc: MA
Thanks!
#1000052 - 09/30/07 08:23 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
These links are for a 2003 Pontiac Bonneville, but it's still the same engine! Look them over and I'll be back shortly.
AllData 2003 Pontiac Bonneville Demo
Upper Intake Manifold
Lower Intake Manifold
#1000053 - 09/30/07 08:29 AM Re: Head gasket blown in 3800 series II motor [Re: Merkava_4]
Drew_Shev Offline
Loc: MA
Wow thanks for the links man, I really appreciate it. It doesn't really seem like a tough job at all.
#1000054 - 09/30/07 08:50 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
You'll need this new upper intake manifold kit. It's much better than OEM.
APN Replacement UIM
I'll be back.
#1000055 - 09/30/07 08:54 AM Re: Head gasket blown in 3800 series II motor [Re: Merkava_4]
Drew_Shev Offline
Loc: MA
I'm a little confused here. What is the problem, the lower intake manifold or upper?
Thanks again.
#1000056 - 09/30/07 09:07 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
It could be either one. The original factory upper intake manifold (UIM) had an EGR tube that runs through it. That EGR tube was designed too large in diameter originally, which resulted in the tube melting the plastic UIM. The new one from APN eliminates that problem.
The lower intake manifold (LIM) originally had its gaskets without the supporting aluminium strips, so it distorted from a combination of clamping force under the pressure of the bolts AND the deterioration from acids in the coolant.
So you're much better off doing them both at the same time. As far as I know, the dealer stocks the second design LIM gaskets, but not the second design UIM and UIM gaskets.
#1000057 - 09/30/07 09:28 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
Some stuff to remember:
Drain the coolant from the radiator first before starting anything else; that's so you can avoid a mess when you go to pull off the throttle body. The throttle body has coolant passages flowing coolant from the UIM.
Make sure you replace the plastic coolant elbows and THIS IS IMPORTANT: apply silicone grease to the elbow o-rings before you install the elbows.
Apply Permatex 2B to the threads of the LIM bolts. I'll explain more later.
Make sure you have an accurate inch pound torque wrench! Snug the bolts by hand first. Make at least two passes with the first pass at half the final torque.
Parts List:
UIM kit with included gaskets (it might include the elbows)
LIM gaskets from a GM dealer (make sure they're reinforced)
Coolant elbows
Throttle body gasket
Silicone grease or dielectric grease
Permatex 2B
Distilled water and new Dexcool
I'll post more info as I think of it.
#1000058 - 09/30/07 09:42 AM Re: Head gasket blown in 3800 series II motor [Re: Drew_Shev]
Merkava_4 Offline
Loc: Clovis, CA
This might be a good time to ask: You do in fact have the normally aspirated 3800 Series II L36 VIN K and not the supercharged version correct?
#1000059 - 09/30/07 09:52 AM Re: Head gasket blown in 3800 series II motor [Re: Merkava_4]
Cutehumor Offline
Loc: USA
GM coolant tabs. heh
09 Chevy Cobalt 2.4L 88k miles Peak 5w30
09 Pontiac Vibe 2.4L 98k miles Pennzoil platinum 5w30
Page 1 of 2 1 2 >
