Typical oil pressures in an engine?
Posted by: HKPolice
Typical oil pressures in an engine? - 04/18/14 10:51 AM
Seems like most filter bypass springs open up at around 12-18psi but when I google typical oil pressures, people are posting figures WAY above that. Apparently it's normal to idle around 10psi and for every 1000rpm it goes up another 10psi?
Wouldn't the filter be in bypass mode most of the time? I was under the assumption that filters don't bypass except for when the oil is really cold & thick and when near redline.
Posted by: bepperb
Re: Typical oil pressures in an engine? - 04/18/14 10:55 AM
The filters open when there is a difference between the input and output sides. It doesn't matter what the total pressure is, only the difference.
So if an engine was driving down the highway with 50psi going into the filter and 48psi coming out and the bypass was 10psi it wouldn't be close to opening.
Posted by: dparm
Re: Typical oil pressures in an engine? - 04/18/14 10:59 AM
10psi per 1000rpm is a ballpark, yes.
Posted by: HKPolice
Re: Typical oil pressures in an engine? - 04/18/14 11:03 AM
Oh ok I get it now. Are there any figures for typical pressure drops for oil filters? Any tests to see the amount of trapped contaminates needed to cause pressure drop?
Posted by: bepperb
Re: Typical oil pressures in an engine? - 04/18/14 11:33 AM
You've come to the right place. This is old but a good place to start:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=314996
At one point someone had a similar setup in their car but I cant' find a link (I didn't look hard).
Posted by: ZeeOSix
Re: Typical oil pressures in an engine? - 04/18/14 01:31 PM
Enjoy ... real test data from Purolator on a PureOne filter of average size (used on a 405 HP V8). As you can see, with hot oil a filter will flow lots of oil with not much pressure drop across the filter.
http://www.bobistheoilguy.com/forums/ubb...451#Post1619451
Posted by: Realtech214
Re: Typical oil pressures in an engine? - 04/18/14 01:32 PM
My silverado has 40psi at idle (700rpm) and about 50 in the morning at idle. With 5w30
Posted by: Zaedock
Re: Typical oil pressures in an engine? - 04/18/14 01:45 PM
As mentioned, oil filters bypass with differential pressure.
This can occur when the engine is cold and the oil is viscous and it can also occur for a moment at operating temp when you go wide open throttle.
Posted by: RF Overlord
Re: Typical oil pressures in an engine? - 04/18/14 05:47 PM
Ford modular (4.6L etc) can have 100 lbs pressure at cold startup, but settle down to 25 at hot idle. I believe this is one of the reasons Ford insisted on putting fake gauge in their cars.
