"break in" oil for turbo subaru
Posted by: 91camarosRS
"break in" oil for turbo subaru - 12/28/13 04:30 AM
I'll be getting a used motor soon for my Subaru. It will most likely have around 50k miles. But has been sitting for who knows how long. My plan was to run xxxxx oil for xxxx miles then switch to rotella t6 for 5 k and get oil analysis.
Question, what steps should I take for new motor? Old trick of spraying marvel into cylinders before starting? Do I use a cheap supertec oil first? How long should I run it? Thank you
Re: "break in" oil for turbo subaru - 12/28/13 04:39 AM
Side question... I'm also getting an oil temp/pressure gauge. I got temp so I make sure car is truly warm before any halfway spirited driving. What temp should be the low? 100? What should my pressure be?and my normal temp?
Posted by: SteveSRT8
Re: "break in" oil for turbo subaru - 12/28/13 05:58 AM
Since it's used there is no break in required. While it's out of the car you should at least consider a look around to be sure it is a good candidate, otherwise it's a bit of a gamble.
As to break in, I believe in no lower gears but LOTS of full throttle in the higher gears for best ring seal. Oil temps once over 120 degrees or so are fine unless you run heavy oils for some strange reason.
Once you get some pressure versus temps data we can tell you more. There's a lot of Scooby folks here...
Re: "break in" oil for turbo subaru - 12/28/13 06:26 AM
I'm looking and have been looking for awhile.
A little nervous on spending all this money!
So no cleaner oil? Something to get anything out to freshen it up?
I'll be running t6 like I.said its 5w-40
Highly recommended for subies.
I have an auto...... Can't do the only high gear thing..
Posted by: Kuato
Re: "break in" oil for turbo subaru - 12/28/13 06:32 AM
I would simply change to the T6 right after you buy it, and maybe have a shorter interval the first time. Good oil is good oil.
As far as hard acceleration in a higher gear...well...that's speed related so get up to highway speed, and accelerate hard, expecting a single downshift.
Posted by: Cujet
Re: "break in" oil for turbo subaru - 12/28/13 07:28 AM
T6 is a perfect choice. If you are really worried, change it out a bit early and continue using T6. No need to worry about break in. And T6 will maintain a clean engine.
You will get another 200,000 miles as long as the head gasket and other issues don't cause problems.
Re: "break in" oil for turbo subaru - 12/28/13 07:46 AM
That's why I'm replacing..... Head gasket. And I can't keep things stock......
Posted by: toneydoc
Re: "break in" oil for turbo subaru - 12/28/13 08:14 AM
Do you really have 110k miles on the 2012 Hyundai already?
Re: "break in" oil for turbo subaru - 12/28/13 08:25 AM
Yes.....
Wife is a phlebotomist and drives 200+miles a day to collect samples from nursing homes
Oil changes have been neglected(wifes car) getting one in the next hour. I will ne on top of that! Plan on getting oil analysis done on it with the new change. We are in for long haul(my car too... She put the miles on my subie) I want/need a oil that that car needs. Ran Quaker for the first 40k or so then dealer switched to Mobil. We get free changes
Posted by: whip
Re: "break in" oil for turbo subaru - 12/28/13 10:02 AM
If the engine has 50,000 miles, it's already "broke in". Run the oil you want to normally run.
Re: "break in" oil for turbo subaru - 12/28/13 10:22 AM
I was concerned about time it sat.
Not typical "break in" just bringing back to life
Posted by: Kuato
Re: "break in" oil for turbo subaru - 12/28/13 10:53 PM
Yes.....
If those are highway miles, it's a good candidate for extended drain...
Posted by: Clevy
Re: "break in" oil for turbo subaru - 12/28/13 11:16 PM
A single used oil analysis is pointless. They are used to establish trends which can then be analyzed for any anomalies so save your money unless you plan on doing them consistently.
As far as the first start some mmo into the cylinders via the plug holes wouldn't hurt. Once it's started I'd do an mmo intake cleaning via a vacuum hose just to insure the top end isn't dried out or dirty.
None of this is required it's merely a suggestion.
Re: "break in" oil for turbo subaru - 12/29/13 02:44 AM
I was thinking,for both cars, to get a baseline. See if anything looks abnormal.
Put oil that "should" normalize. Then check again.
Or in my Hyundai, see how long I can go between changes. Or should I get a better oil etc
Posted by: toneydoc
Re: "break in" oil for turbo subaru - 12/29/13 07:42 AM
I would use Mobil 1 extended performance in the wifes car and use it for 12000 miles or so which in her case will be 4 months or so. And rest assured that that car is ok.
Re: "break in" oil for turbo subaru - 12/29/13 08:55 AM
That's all my Subaru saw....
Then I heard about t6.....
I guess ill do that next.
Or maybe I should run m1 ep for 12k, then take analysis and see if its ok.
Wix,OEM,or puralator gold/one? Or fram?<just kidding
