- Joined
- Jun 2, 2003
- Messages
- 23,591
I would like to know what thread locker will resist contact with Red Line CV2 grease the best. It should be a medium strength thread locker and it does not have to be very heat resistant.
Quote:
Chemical / Solvent Resistance
The product retains effective properties in contact with
automotive fluids, such as motor oil, gasoline, brake fluids, transmission fluids, alcohol and antifreeze solutions.
Quote:
I want a thread locker that I can use to prevent a bolt from backing out of a propeller shaft.
Quote:
Propeller shaft?
Quote:
The proper term for what lay people call a drive shaft on an automobile is Propeller Shaft -- or prop shaft.
Quote:
What most of us call valve covers are Rocker Arm Covers (RAC). There are several other terms, but these are the ones that come to mind at the moment.
