Jag,
Interesting chronology. It's amazing how sensitive this engine is to oil choices because I've also noticed nontrivial changes in gas mileage and turbo response depending on the oil used. My chronology is:
5k drained factory fill (averaged 33.4 mpg on trip from Ohio to NC on factory fill). Replaced with dealer castrol GTX.
Turbo response slightly worse, but gas mileage held.
7.5k replaced with a second dose of dealer GTX.
10k Valvoline Synpower 5w-40. noticeable increase in turbo response but mileage dropped to 32mpg on Ohio/NC trip.
25k tried GC for the first time. Sluggish turbo response, mileage stayed the same until about 1200 miles into interval. Then got unbelievable spike (up to 35.5 on NC/ohio trip). Then MPG decreased again. I suspect the GC thinned and then thickened again, but its just a hunch. In any case, the sluggish turbo response was enough for me to abandon GC.
30K Filled with Maxlife Synthetic 5w-30. Turbo response improved over GC. Mileage got worse (32mpg), but was about same as with Synpower 5w-40.
Been running maxlife synthetic ever since (68,500 miles now). Turbo response has remained good and no sign of oil consumption. When I open the oil cap, there is a brownish coat on the metal parts but I can use my finger to wipe it off so its not hard. I'm currently 3,500 miles into this interval. What do you make of the brown coat? Anything to be concerned about?
In any case, the latest batch of maxlife I bought no longer have the VW50x or MB specs on bottles. A valvoline tech told me they don't plan on meeting those specs in the future so I may be switching to another oil. It sounds like M1 0w-40 might be a good candidate.
