Remember, TBN doesn't necessarily drop linearly. From what I've seen, it seems to drop most quickly at first, then level out, and can stay at an acceptable lower level for quite some time. This is the opposite of what I expected...I expected it to hold high for quite a while, then drop precipitously as the buffering agents became saturated, or used up, or whatever happens to them, because that's more like the way that blood in humans behaves. Obviously, even if Oil in an engine is often called the blood of the engine, it's buffering systems don't act the same.
