Hi,
I've got a set of used headlights. The lenses are made of glass (not plastic) and they have some stone chips and scratches. The most annoying is that the surface is a little rough and looks like if you spray some paint on the headlights. However this is not paint, it's like "glass corrosion" or whatever.
Is there anyway to remove at least partially this "glass corroded" layer to make the glass clear? I'm looking for a cheap DIY to do it. There exist some kit out there that are supposed to do the job with special polish and finish but they are far too expensive. Is it possible to sand the surface of the glass? Any other recommended product to remove this "glass corrosion"?
Thanks
Thanks
