Quote:
Quote:
SO if I'm using Shell,(or should I say top tier) is there any need to use any additives like techron or redline? Or is that going to run my engine clean?
Let me say
this about
that :
I had some pinging appear last fall so I started using Top Tier gas continuously; mainly Shell, and many many tankfuls of V-Power. Even with the onset of cold weather and the use of expensive V-Power, the pinging got worse. I also used Petro Canada and Sunoco (both Top Tier in Canada) but nothing changed. It would still ping with 89 octane and only 91 octane or greater would stop it (even then I'd hear the occasional ping).
10 days ago I dumped an entire bottle of Redline SI-1 into the tank, filled it up with 89 octane and away I went. By the time that tank was gone, the pinging was also gone. So I refilled with 87 octane and dumped in 1/2 bottle of Redline SI-1 and when that tank was gone, I did that again. I'm now on 87 octane with no additive and there is zero pinging. Nothing. And there is a noticeable improvement in acceleration. All that in 10 days, 3 tanks of gas and 2 bottles of Redline.
In my case, Top Tier gas did absolutely nothing. Since Redline SI-1 cleared up the problem, and since SI-1 cleans injectors and deposits from intake valves, it must have been deposits that were causing the pinging (it usually is, but not always). But Top Tier gas is supposed to clean deposits also. Since pinging not only remained but got worse during several months of TT gas usage, I can only conclude that it was useless as a cleaner, and may even have added some deposits. As far as I'm concerned I wasted alot of money on "premium" TT gas. I think the "premium" designation was promoted by the Accounting Dept because 91 octane is almost 40 cents a gallon more expensive here than plain old regular. I could have bought a dozen bottles of Redline with the extra money I wasted on premium TT gas.
That's my experience. It does not mean that you will experience the same thing. We have different engines with different designs and different levels of deposits.
Phil
