Used vs. new won't make much difference if still same size. If changing tire size, you wasted money on first align. Did shop give you printout of before/after specs at time of align? As bdcardinal mentioned, aftermarket parts are available to make lowering work properly. If you can't afford replacement parts, raise 'er back up and save them pennies!
Bob
