Patman
Staff member
I've been using my mom's 2001 VW Golf (2.0) for the last few days, and on the cold mornings the low coolant warning light has been flashing. So this morning I added a half quart of green coolant I had lying around. After doing this I read the owner's manual (I know, I should've done that first!) and found out that these engines use a special coolant! DOH!
Is there going to be any problems with this? The manual makes it sound like the engine is going to self destruct if you mix green coolant with this stuff. What's the worst thing that can happen here?
