My 2002 Honda CRV has a timing chain instead of a belt like my Civic. Honda recommends changing at 100K or so. Question is:
Can the chain be driven longer before a change over a belt due to strength versus a belt, or is Honda right in recommending the chain be changed as often as the belt?
Also if you think it can go further, what would be the upper limit of time/miles would you go?
