This may be it
This is for the F6A-T engine
MAZDA
GF-HN11S
F6A-T
P502024
Representative Image
Click to view larger image LUBE SPIN-ON FULL FLOW
Application Details
View Product Line Drawing
Purchase this Product:
Quantity
Lube Filters Product Attributes
A - OD (Inches): 2.68
B - Thread Size (Inches): 3/4-16
C - Length (Inches): 2.56
D - Gasket OD (Inches): 2.56
E - Gasket ID (Inches): 2.2
Relief Valve Setting (PSI): 11-17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: BRIGGS & STRATON 492932,
Primary Application 2: SUZUKI, DAIHATSU, MAZDA
This crosses to a:
Part Number: 51056
UPC Number: 765809510562
Principal Application: Various Lawn + Garden Equip. + Small Tractors w/ Kolher, Lister, Hatz, Kawasaki Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.707
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
The gaskets, and diameter, are slightly different.
