I have a 11 second rebuild in the works and i decided to go with schaeffers dino oils.My question is would it be ok to use an oil with good amount of moly like shaeffers oil from the first start up braek in procedure? Because i read were you should not use oil with moly then i read that it is good to use.what are your recommendations.It is a roller cammed motor 3.8 turbo.
Thanks
Thanks
