hey Blazer freaks - has anyone used aftermarket rear brake pads from Murrays or Autozone? I did a rear brake job today on a 2000 blazer 4wd (with the drum in hat parking brake). funny thing, every brake pad set at BOTH murrays and AZ did not fit into the old caliper bracket. went back to both stores twice, and second time had them pull out a new semi-loaded caliper (w/o the pads, but with the bracket. neither store had a "fully loaded" caliper in stock..hmm wonder why) - and nope, the new pads didn't fit in the new calipers either! they were just a tiny bit too long -- they could've been forced in with, say, a hammer, but then they would be stuck and could not move. and further yet - the old brake pads were absolutely frozen into the caliper brackets...almost as if someone forced them in with a hammer (it took a hammer to get them out). hmmm. so I finally just got the chepo AZ duralast ones and took them to my grinder to shave 0.5mm off each end so they would slide freely in the pad retainers. greased them up good and put it all back together.
so has anyone else with a Blazer seen this?? I can't be the only one, especially since the reman calipers don't even match the pads.
