Do any of you guys do this?
they sell oversized drain plugs to solve your problem. it would be alot cheaper and a ligimate repair.quote:
Originally posted by paulo57509:
Do I do this? Not unless the pan threads are toast. I've had to do this to the plug on the Legend.
The threads in the pan finally got wiped out after all these years. It would actually damage the threads on a new drain plug; made them look more like buttress threads than regular threads.
The plug would leak even with a new sealing washer.
I wrapped a huge amount of tape onto a Fram Sure-Drain and installed it. No leaks. Now I don't have to deal with making the leak worse by removing the plug. I just use the Sure-Drain. It sure is slow, though.
Some day when I feel ambitious, I'll replace the pan. Timing belt change is coming up.....
Even though I've always used a torque wrench on the plug, the previous owner apparently didn't. Curious....it took 4 years of routine (5k mile OCI's) to get the plug/pan to strip.
Agree! Teflon tape is not recommended for applications that see vibration as it can loosen up. It’s good for static applications like home plumbing.quote:
Originally posted by 1sttruck:
I have pipe threads on the transfer case and tranny fill plugs, so I used a bit of Teflon pipe thread compound on the plugs. It seems to set up a bit, which was more reassuring than using tape.
Lubricated threads also have a much stronger chance of overtightening & loosening from vibration.quote:
Originally posted by Big John:
Teflon tape is a lubricant not a sealer,most of what you wrap on there will be sheared off as you thread in the plug..
