OK, my 2003 Toyota Matrix has about 14,300 miles on it now. The power steering fluid is looking rather brownish-black so I assume it's long overdue. How much will it cost, usually, to have it flushed and changed?
Stay off the stops when parking, back off as soon as you hit them and try not to hit them.quote:
Originally posted by Blue636:
Is there any other way to flush it and change it besides the way you mentioned? Otherwise I might have to adopt your technique or get some sort of wet-vac and suck out the fluid from the reservoir and replace it.
I think your math is questionable.quote:
1/3 x 1/3 x 1/3 x 1/3 = 1/81 or about 1.25% of the original fluid in the system
And the problem is?quote:
I think you meant 1/3 + 1/3 + 1/3 + 1/3 = 4/3 = 133%.quote:
And the problem is?
I'll have to try this method the next time, when I order a service manual. I know, I should already have one by now...quote:
Originally posted by Kestas:
If you want to do a flush instead of diluting the fluid, here's the way. You'll need a helper. The steps are rather simple.
1. Lift front tires off the ground.
2. Disconnect the return line, drain ps reservoir.
3. Plug open connection at the reservoir.
4. Secure the return line to a generously-sized container (at least one gallon). If needed, add a length of hose.
5. Fill reservoir.
6. Line up your bottles of new fluid for quick pouring.
Here comes the fun part...
7. Have helper turn car on, and immediately have him go through full range of steering motion (left and right) and shut off car, all the while you are trying to keep the reservoir filled.
8. Button everything back up.
9. Clean up mess.
10. Top off fluid.
The front tires must be off the ground so the system is unloaded, otherwise a lot of fluid is pumped out wit a lot of force. The return line must be secured to prevent a big mess. Keep at least a gallon of ps fluid on hand. The helper must know what they are doing.
Anyway, so you guys are saying that I can open up the reservoir, suck out as much as I can with a turkey baster, then replace it? And I do this once every day for four days to get as much out of the system?
I've used the Turkey Baster method and have done the process 5 times, and my PS fluid is still coming out dark. If it doesn't clear up soon, I'm going to have to disconnect the return line.quote:
No, his reasoning IS okay. If you reread his post, he says that he LEAVES 1/3 of the fluid, meaning he removes 2/3.
So it's more like 33%, 11%, 4%, 1%.
Not bad numbers and looks rather attractive if you want to avoid the pain in using the flush method I posted.
