My dad just bought a used Cub Cadet with a Kohler Series II KT19 (19hp) engine. THe onwers manual states:
Now the problem - My dad wants to use a quality oil other than Kohler's. He will be running this engine from below 0F up to 90+F. This engine has a sump of 1.5 pints with an addition pint in the filter - it is air cooled, so a quality oil is needed with only 2.5 pints of oil.
I have recommended the following choices -
Amsoil 4-stroke 0w-40
Amsoil SAE 30 Heavy Duty Diesel Oil
What does everybody else think? He needs an oil that will flow when it is extremely cold and one that will continue to protect up to 90F. Any suggestions?
[ September 30, 2003, 09:27 PM: Message edited by: medic ]
By the looks of the chart 5w-20 & 5w-30 can be used below 32F. 10w-30 can be used between 0F & 32F. and the Kohler Magnum 30 wt can be used above 32F. And at last, the Kohler "Winter" 30 wt. can be used in all temperatures. The oil must be API service class SG or SH.quote:
Straight 30-weight (Kohler "Magnum") oil is preferred. SAE 10W-30 is not recommended above 32F. Using this oil substantially increases oil consumption and combustion chamber deposits.
