Well it shows a SMF-109 for the '99 - '02 SV650. I doesn't show a filter for the '03 and newer (second generation). I'll have to find out if this will work on the newer bike and not just assume it will.
I bet it does fit, call the suzuki dealer and ask if it uses the same filter. I change my motorcycle oil quite often and also use amsoil filters since Honda wants about 17.00 for there filter!
I use most Amsoil products BUT the MC filters. The one I got for my VFR just felt and looked cheap compared to the Honda OEM unit. It was lighter and I could dent (crush) it real easy compared to the OEM. Plus, the local dealer sells the stock Honda filters for about $7 bucks - same as the cost for the Amsoil filter. BTW - I use the Amsoil 20/50 and the tranny really loves it!!
I could tell you that. It's not worth ordering just 1 filter. Now if you order a case of oil and a couple of filters, the price of the shipping per filter is like $.66 Then it's reasonable. Otherwise it's a waste.
Same with just ordering 4 quarts of oil. Shipping will increase the price dramatically.
