Wet clutch should not be affected negatively if used at 2 ounces per qt treat rate or less..
Yes the valves will be cleaned and allowed to be freed if that is the cause of the sticking valves and not a mechanical issue.
Too bad you don't have some Fuel Power for the gas to help too.
Was recently in Peru an thought about you.
When and if I get to Bolivia I will look you up.
[ April 07, 2004, 06:09 PM: Message edited by: Terry ]
