Looking for some guidance on my old-ish Cub Cadet lawn mower. It has the B&S 6.5 engine, does not have the words 'Intek" or "Vanguard". "Professional Plus," maybe. Oil is full, changed annually with whatever 5w30 or 10w30 is closest at hand. Probably QSGB right now, SL grade.
Before I start any OPE, I always pull the rope a few times to verify easy turning before I yank my shoulder out. The last couple weeks with this mower, it's been making a grinding/scraping kind of sound. I thought it was clippings built up underneath so I scraped it as clean as I could after my last cut. Same noise this week. However, after I tickle the carb the usual 12-15 times, it starts on the first pull with the normal single blue puff it has made for the last 10-12 years. After done mowing, pull the cord slowly and no grinding noise.
Any ideas on some simple things to look at?
I like this simple mower. 6-speed RWD self-propelled. Single lever height adjust. No problems with anything except the grinding noise. I bought it as a closeout mower in 2004 or so.
