Originally Posted By: supton
Honda M77 I belive The_Critic (or The_Eric?) recommends this stuff. I tried it recently, and found it does work much much better than Sta-Lube.
It is absolutely amazing how it works on brakes in areas with lots of snow. It reduces or eliminates corrosion like nothing else I've tried over the decades. No type of anti-seize even comes close.
Honda's "Moly 77" is a much-less-expensive copy of the true Molykote M77, but I am assured that it works identically to Molykote's version. Honda's part number in Canada is 08798-9010CH. Might be different in the US.
