My ram has an issue where if you are driving and hit a bump or anything unsettling at all. The trans will pop out of drive into neutral. The selector is off as well 2nd is drive D is neutral ect and park usually requires a slight amount of force to get it all the way In. My question is what could cause it to do this. Mounts are good external linkages appear ok. I'm wondering if it's in the column. I'm not real familiar with how it is set up. Has anyone had any experience with this or having these coullumns apart? Any advice is appreciated .
