Originally Posted By: clinebarger
I did find a LS3 longblock for $4500 but I think it's stolen....So I passed. Besides I would have to buy a 58X to 24X converter box or change the Crank Reluctor & Cam Gear.
That's A LOT for just a used long block when you can get a COMPLETE (for the most part), BRAND NEW Chevy Performance parts LS3 crate engine for ~$5700.00 for the factory 430 horse version, or ~$6250.00 for the 'Hot Cammed' 480 horse version.
I am thinking of doing the latter, even though I
barely trust the Lingenfelter conversion box needed to make it work without a full bottom end rebuild on a brand new engine just to get that blasted 58 tooth reluctor off and my 24 tooth one on the crank.
We would also need the cam position sensor harness extensions, and a drill and tap job to install our knock sensors into the side of the block, instead of in the valley, were they reside now in our early LSxes.
The stock LS3 knock sensors will NOT 'talk to' our LS1 ECM.
Sorry, It was a complete LS3 with a TR6060, A/C Compressor & E38 PCM where the only missing items, But still would have been a Longblock with Intake & Injectors for my intended purposes. Seller could not (Would not) verify where the Engine came from. When I asked if Fort Worth PD could come by & confirm it wasn't stolen. They left in a hurry.
OK. you did not mention the TR6060 (which are what, almost $5K now new by themselves??) was included, and I thought it was even minus the intake/injectors/fuel rail/front cover/etc. for that price, like
most of what are labelled 'long blocks'.
In that case YES, I would put money on that assembly being stolen.
