My Jeep has been sitting for about 10 days now with no oil pan. Little worried that the oil pump and drained out completely out of the pickup.
Once I get the thing back together I am going to pull the plugs and just spin it over with the starter for a minute or two - that shouldn't cause any damage to the starter since there's no compression. They only overheat if they are spinning the engine over and there is compression.
On a side note, how does one forget to put oil back in and get that far? Wouldn't there be an oil pressure light?
Originally Posted By: IveBeenRued
OP, this situation reminds me of this guy: https://youtu.be/-UCxmJiRpjs?t=11m2s but your neighbor did it on accident while this guy knew exactly what he was doing. Excessive wear probably occurred but unless he does a tear down he will probably never know if there was any damage.
I was thinking of the same video!
