I have a 99 F150 and just replaced the door lock actuators that failed. The locks work great however now the Power Window on the drivers side will go down about 25% then get really slow until you have to help it with your hand and then gets faster at the bottom. The passenger side seems to be affected to a lesser degree. The passenger side drags a bit but works without manual assistance. Any ideas on why this happened right after actuator replacement? I tried not to damage anything while replacing the actuators.
