Originally Posted By: boostedtsiawd
Because mine is supercharged.
Both my vehicles are forced induction, the Caprice with the L67 3.8, and the Nissan a ZD30 turbodiesel.
Both warm the coolant significantly quicker if I drive to the edge of town with the Caprice in "2" rather than drive, and the Nissan in third gear (manual), holding the revs around 2,500RPM.
Here's a trend from a paper with a couple of different oils, frictional losses at 60C oil temperatures versus RPM.
Blue line, reference is about 3hp in friction at 2,500RPM versus just under 1-1/2 at a fast idle.
2,500RPM will provide (obviously) twice as much heat through viscous drag as sitting at idle...i.e. better warmup.
