If the OE has grease fittings then you don't have a lot of alternatives, if you buy the Moog buy them from AA and use a coupon code.
Check the boots carefully where they go on the the joint at the bottom right there in the store.
If there is any sign the machine nicked or the boot isn't on square then refuse it and ask for another. I went through 3 sets before finding two with pristine boots. Ordering online and your taking a chance.
The metal used in the Moog problem solver joints is good, that's not an issue but it sucks to have the boot blow out even under slight pressure when you go to grease it.
