Originally Posted By: Ethan1
The inner rocker panel and any rocker reinforcements are certainly very strong; however, the outer rocker is not solely cosmetic. Actually, all of the sheet metal has to work together as a system.
Besides, if you can see rust on the outer panel, the inners are probably already shot.
Looked at a 94 Corolla where much of the rocker was gone, but the inner metal was mostly there--maybe at the very bottom, at the seam it might be wicking upward, but only the outer curved area was gone. Did not think much of it. Next time I look at clunkers I'm going to have to look more closer, as now I'm curious if the inners are as destroyed as you say.
OP is talking about the part you'd step on if you were a 4-year old climbing into the rear seat. It curves around and down but then just stops.
Yes, that area is where I'm talking about.
