My Daughter's Cube needs a set of front pads and rotors. I usually do my own brakes, depending on the vehicle. For example, my Corolla is very easy to do. Pull the wheel, remove the caliper, and remove the bracket that holds the rotor in place (I call it a keeper) and that's it. I attempted to do the brakes on my MPV, but those rotors are pressed onto a spline and require a special puller that I don't have. Does anyone know if the Cube's rotors are easy to remove and replace?
