Oh, wait. That was somebody else... or was it? [/quote]
It was somebody else. GHT is back on here under a new name (he has revealed himself), and it's not engineer20. [/quote]
I've been awaiting his arrival
[/quote]
Struggling, yes. I got that thing on as best I could. Probably should have waited for a stud, then I would have drilled again.. Whatever it's crazy torqued on (that bolt) and the rest are right, if it fails, it will be either between cyl 3 and 4, or Cyl 1.
Engine is timed, motor mount going back on, exhaust bolted back up, engine is on a jack. Intake manifold has most the bolts on, gonna tighten and try to locate the ones around 3 and 4 because coolant flows there.. then it's simple of the brackets, AC, fan, radiator, ignition stuff, brake reservoir, PS fluid reservoir, gonna just use the Denson plugs, old [censored] wires, why even open the NGKS and new dizzy I got.. got oil in there ready to go to flush after 60 or 90 seconds, from old mayhem.. H-T can watch from sidelines..
Goal is by Thanksgiving, the anniversary of it stolen.
Honda name: Cleopatra. Listen the the Frank Ocean song "Pyramids" to hear why.
Sup yall. [/quote]
'prone is back !!!!!!!!!!!!!!!!!!!!!!!! good to have you back, man.let the entertainment begin.so, did you ever find your magic beans ?
have a good day.
Sup yall. [/quote]
have a good day.
