Usually, it seems, when running the cold air when the weather is damp and about 70 degrees Fahrenheit that windows will fog. Now usually you could roll the window, but if it is raining it could let water in and if you do close the windows after intaking some rain- it seems the fog could get worse.
Is the only wait to fix fogged up windows ( or prevent them), without the use of compressed cold air air conditioning t use HEAT, thus sweating bullets? Or is there a way to keep in relative comfort and have good visivility?
Im mostly talking 70F and above....to say 90F....
thanks
thanks
