I'm not taking a stand here, but here are the ranking in testing done by 540 RAT:
Here are the 13 Diesel Oils that were tested. And they are ranked in the order of their “Load Carrying Capacity/Film Strength” values:
1. RED LINE, 15W40 Diesel Oil, synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O
“Load Carrying Capacity/Film Strength” = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
moly = 173 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 2999 ppm
TBN = 8.3
The onset of thermal breakdown is approximately 285*
2. ROYAL PURPLE, 15W40 Diesel Oil, synthetic, API CJ-4 /SM, CI-4 PLUS, CH-4, CI-4
“Load Carrying Capacity/Film Strength” = 76,997 psi
zinc = TBD
phos = TBD
moly = TBD
total detergent/dispersant/anti-deposit build-up/anti-sludge = TBD
TBN = TBD
The onset of thermal breakdown is approximately 265*
3. MOBIL 1 TURBO DIESEL TRUCK, 5W40 synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7
“Load Carrying Capacity/Film Strength” = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 1596 ppm
TBN = 9.3
The onset of thermal breakdown is approximately 270*
4. CHEVRON DELO 400LE, 15W40 conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, SM, SL, “Load Carrying Capacity/Film Strength” = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
moly = 80 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 2205 ppm
TBN = 8.0
5. MOBIL DELVAC 1300 SUPER, 15W40 conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL , “Load Carrying Capacity/Film Strength” = 73,300 psi
zinc = 1297 ppm
phos = 944 ppm
moly = 46 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 1843 ppm
TBN = 9.8
The onset of thermal breakdown is approximately 250*
6. Farm Rated 15W40 Heavy Duty Performance Diesel, conventional, API CI-4, CH-4, CG-4, CF/SL, SJ
“Load Carrying Capacity/Film Strength” = 73,176 psi
zinc = 1325 ppm
phos = 1234 ppm
moly = 2 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 1593 ppm
TBN = 9.3
The onset of thermal breakdown is approximately 255*
7. SHELL ROTELLA T, 15W40 conventional, API CJ-4, CI-4 Plus, CH-4, CG-4, CF-4,CF/SM
“Load Carrying Capacity/Film Strength” = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
moly = 0 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 2886 ppm
TBN = 9.1
NOTE: This new Rotella T has SIGNIFICANTLY MORE zinc than the OLD Rotella T, NOT LESS as is often claimed. And these two Rotella oils were Lab tested more than a month apart. So, their component quantities had no chance of being mixed up. This new Rotella’s wear protection capability is just slightly BETTER than the OLD Rotella. Therefore, the new Rotella is NOT the junk some have claimed.
8. “OLD” SHELL ROTELLA T, 15W40 conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH
“Load Carrying Capacity/Film Strength” = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
moly = 0 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 2715 ppm
TBN = 10.1
NOTE: There is ABSOLUTELY NOTHING special about this OLD Rotella, as so many have always claimed. That was only folklore. It is simply ordinary Diesel oil.
9. VALVOLINE PREMIUM BLUE HEAVY DUTY DIESEL, 15W40 conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF/SM
“Load Carrying Capacity/Film Strength” = 70,869 psi
zinc = TBD
phos = TBD
moly = TBD
TBN = TBD
10. CHEVRON DELO 400LE, 5W40 synthetic, API CJ-4, CI-4 Plus, CI-4, SL, SM,
“Load Carrying Capacity/Film Strength” = 69,631 psi
zinc = TBD
phos = TBD
moly = TBD
TBN = TBD
11. SHELL ROTELLA T6, 5W40 synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4/SM
“Load Carrying Capacity/Film Strength” = 67,804 psi
zinc = TBD
phos = TBD
moly = TBD
TBN = TBD
The onset of thermal breakdown is approximately 260*
12. LUCAS 15W40 MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL
“Load Carrying Capacity/Film Strength” = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
moly = 76 ppm
total detergent/dispersant/anti-deposit build-up/anti-sludge = 3393 ppm
TBN = 11.7
13. CASTROL GTX DIESEL, 15W40 conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4/SN
“Load Carrying Capacity/Film Strength” = 66,323 psi
zinc = TBD
phos = TBD
moly = TBD
total detergent/dispersant/anti-deposit build-up/anti-sludge TBD
TBN = TBD
Does not include Amsoil or JD Oil. But does include Delo and Rotella. These are just extreme wear tests and do not include cold flow, etc. But Delo generally ranks higher than Rotella in testing I have see. Maybe not by much, but something.
I'm not a 540 RAT fan boy. But since his testing is the same a repeatable for him and his test rig, I'll by the results for extreme pressure wear resistance.
I dunno if these VW TDI engines have cam/lifter issues or not... But, if they do, the results above might be worth considering ...
