Tight moog front end parts - best grease?
Albany, NY
I've isolated my steering issue(memory steer) to what I believe are very tight moog front end parts. It is not the box as I thought, there is little play when the pittman arm is naked.
Disconnected stuff, the only thing left in the linkage was the idler arm and it seemed [censored] tight. As I connected more things together the steering became harder. I added a lot more grease to the joints and my butt dyno tells me resistance is going down.
I am currently using Valvoline F/M/L grease.... Wondering if I can do better in terms of slipperiness/lubrication/whatever? It seems to be good stuff but I think these parts could use the best.
My car was like that for a month or so after I replaced a bunch of front end parts. After that it loosened up enough that it behaved much nicer. How long has it been since you put the parts in?
I thought I had the best ball joints in the world, XRF. I had memory steer after installing these ball joints and subsequently changed them to Beck/Arnley which I believe are reboxed Deeza. The memory steer is gone and I now have about 20,000 happy miles on the Beck/Arnley ball joints.
I prefer dark grey Moly-lithium grease.
My mechanic prefers red Hi-temp lithium grease.
My neighbor (heavy equipment mechanic) prefers green Polyurea grease.
The Ford-spec valvoline is a fantastic grease for chassis parts, a little low max operating temp but thats not an issue here. And a healthy dose of moly. I forget how much but memory says 3% from when I researched it a few years ago. Personally I opt for the Synpower; a little more money but much wider operating temp range and still moly. Valvoline told me 1% a few years back but it certainly looks/feels like more to me. Definitely resembles the Jet-Lube Moly Paste more than a red lithium...
Just solved a wicked memory steer on my GT when I upgraded to Cobra a-arms. The original BJ on passenger side was so indexed it was unmovable by hand.
Going on 1000 miles already, so I'm getting worried. I initially thought it was the steering box, because the parts are so pristine.
Years ago while searching for the "holy grail" of greases thought I would choose Chevron Ployurea. After a discussion with a Chevron lube tech I settled on Delo EP #2. The tech stated that the Polyurea wasn't compatible with conventional greases. A little "FYI".
