Hello im going to change my transmission oil but im not doing a flush just the normal drain.
im going to using royal pruple AFT or either valvoline maxlife ATF....my question is that since all the old transmission oil would not be able to taken out...would it be able to mix with the new SYNTHETIC oil without any problems. Please note the transmission oil was never changed and the vehicle has about 150 000 km on it. Factory oil i believe to be conventional oil
